Ground Control ?s
  • rwh11385
    lance_entities
    • 18403
    Originally posted by nando
    Originally posted by rwh11385
    My rears are SA, but the type you need to remove them, and compress to adjust. It's just something to think about.
    actually, you don't have to remove them if you can get the bump stops out easily. mine fall out when I raise the car, then it's just a matter of rolling the rear up on a pair of ramps, taking off the 19mm trailing arm bolts, compressing them and adjusting them. You might be able to get away with just taking the bump stops out completely, then you wouldn't have to worry about that step.
    yeah, i was kinda thinking they could be adjusted without completely removing themor whatnot, but it'd still be easier to turn a knob. :P
    • 808BMW
      • 2910
      Yeah, I love adjusting them, because I can :P
      Knobs are cool.
      • rwh11385
        lance_entities
        • 18403
        You like playing with your knob Chris, eh?
        • Bryson
          • 1490
          I lied, I ran my part numbers yesterday through GC-- I have 6" 375lb/in fronts and 5.5" 475 lb/in in the rear
          • rayz
            • 494
            mine are Front= 51392 (the only numbers i found) they are 5" springs and lower 2.5" supposedly and the rears are 44350 0500.225.0500 5inch spring lowering 2.25"
            FOKAI DA'MA'SHI'I ENSANE GRAPPING INT.
            • 808BMW
              • 2910
              I would rather play with my knob than pull out the whole thing, squeeze it and twist it around :P
              • rwh11385
                lance_entities
                • 18403
                It's lame doing it yourself. I'd rather have someone else whip mine out and fiddle with it. They can also clean up the mess.
                On a different topic, I DO hope to work on my own suspension this summer.
                • JPbmw
                  • 466
                  Ahahahaha.
                  so there is a 5.5" rear spring height also?if so it seems like the perfect height
                  '86 325
                  • rwh11385
                    lance_entities
                    • 18403
                    Yes. When I was talking to the GC guy when ordering my 6" spring, he was surprised I had a 5in spring, as he said the 5.5in is the popular in the E30 application. So Bryson's 5.5 length does not surprise me.
                    • golde30
                      • 11464
                      u guys and yer puny 5.5"....LOL
                      IG: @Baye30
