Mono Wiper Install?
  • e30ryan///m3
    • Dec 2005
    • 249
    Mono Wiper Install?
    Hey guys,
    Just wondering if any of you have installed a bonrath mono wiper system before? I just received mine (thanks Nico!) and the instructions are completely in german. I have removed the plate that covers the blower on the firewall and the motor is out of the car at the moment so I just need to know how the old wiper mechanism comes out? If anybody can give me any help I woul really appreciate it.
    Thanks,
    Ryan
    P.S. - I searched but nothing came up.
    1988 M3 (Diamondshwartz)
    2004 M3 (SilverGray)
  • Dave
    E30 RAT
    • 11675
    After you remove the blower motor, remove the wiper motor in the car from the linkage (not easy) and you will find the linkage comes out then.
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • xLibelle
      • Aug 2004
      • 2673
      That process sounds down-right silly.
      Why not just pull the caps from the wipers, remove wipers and then the washer style nuts from the wiper axles.
      There is one bolt inside to the firewall to be removed and then twist the whole assembly out of the opening.
      Granted that part is a little tricky but its got to be easier than removing the motor from the linkage assembly IN the car.
      • madjurgen
        • May 2005
        • 1203
        Remove the motor and linkage together. It will fit through the opening but it does take some persuasion.
        Have fun trying to get the wiper to swing through the correct angles.
        As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
        You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
