Low Engine Oil Pressure on dash
  • dinanm3atl
    • Feb 2007
    • 7305
    Most all of the lights come on when you put the key to the on position. The oil pressure, brake lining and parking brake do not.
    Is this normal. I wanna confirm that the light works :) Where is the oil pressure switch and how do I test it?
    • 37833
    It should come on. The oil pressure sender is on the bottom of the block on the front passenger side of the motor.
    Grover Beach, California
    BimmerHeads.com
    • fretburnr
      • Jan 2005
      • 1496
      all three of those should come on with the car off/key on.
      of course, the parking brake one will only come on if it's set.
      Jay
      • dinanm3atl
        • Feb 2007
        • 7305
        I will test the sender. Then check the bulb. Not driving till I confirm :)
        • AdamF 88iS
          • 2051
          Park Brake does check itself when the key is first on. The only one that doesn't is the Brake Lining one- that one does its self test only when the starter is engaged.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
          • dinanm3atl
            • Feb 2007
            • 7305
            well it does not. I parked the car till I can test it. Have to drive the M3 now till this weekend :(
            DIY someone on here for instrument cluster removal?
            • MarshallM
              • Feb 2007
              • 229
              When I worked at a Porsche shop we had a guy who always bitched about something when he got his car back. So one day he comes to me asking what I did to his car. "when I turn the key on all the dash lights turn on, it didn't do that before. I think you fucked something up with my electrical system." I said I would be more worried if the light didn't come on if I were him. He stared back confused and angry. "Its called a bulb check sir thats how you know your dash lights still work, your supposed to check whenever you start the car. Porsche designed it that way for a reason."
              Shut him up real fast.
              • dinanm3atl
                • Feb 2007
                • 7305
                hahah
                well I know what it is supposed to do. I was confirming which ones in e30 are supposed to come on :)
                Making sure I have oil pressure!
