I've been reading a bit about tuning the AFM - how do I know which direction to adjust it, if any?
How do you tune the AFM?
I'm thinking of cheating on my emissions test and making the car run more rich. Going to retard the timing and maybe close off some air supply?"We praise or find fault, depending on which of the two provides more opportunity for our powers of judgement to shine."Comment
Tighter = leaner
Looser = richerRecent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
trent
trent
are you talking about the Fuel Quality Switch? I know the m3's DME has an FQS that can make the motorn run richer/leaner. If you want it to run richer for a short period of time, just change the FQS position in the DME and that should take care of it. I'm pretty sure you can add/subtract a couple of degrees of timing to achieve the desired change. Again, I know for a fact this is on the e30 m3, but not certain if it's on the m20/10/42 powered e30's or for what model years.
hth.PNW Crew
90 m3
06 m5Comment
