My car's new weight savings technique...
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    So last fall, during my fight with mono (before you laugh, I nearly died from it...) I had nothing else to do so I figured I'd do a serious cleaning of my car. Once I had the seats and carpeting out it just seem logical to remove some of the sound deadening and start shedding some weight. I stopped before it got too out of hand (probably because I fell asleep) but my car seemed to have liked the idea based on it's behaviour today.
    I never did get to shave much weight off the front end so my car decided to do the work for me and started by ejecting the aft-most spark plug. I discovered it was loose yesterday so I tightened it up and went on my way but today was not so simple.
    TicktickticktickPopPopPopPopPOPPOPPOPPOPKAPOW!!
    Fortunately the spark plug somehow landed on my exhaust pipes so at least I still have it but the threads on the head are completely stripped. I'm not sure what my options are now but I'm hoping I can somehow use this as an excuse to do my motor swap...
    After all, you know what they say: The light at the end of the tunnel is an M52... :D
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
  • Mastrcruse
    • Sep 2005
    • 5340
    We had this happen in one of the cars me and my dad was working on...might have been the MGB but I can't remember.
    We had it filled/ redrilled or something like that. I dont' know how the motor guy did it but he did. Worked great afterward, no problems. I can be done but don't think its a minor thing. I could be wrong though
    So I know this doesn't help that much but I will ask my dad to see what the motor man did.
    • Fidhle007
      • Oct 2005
      • 7209
      Yeah, if it involves pulling the head it's basically worth it for me to just put in the extra hours and swap the motor. The money that I'd probably spend having a machine shop plug and retap the head I'm sure could be spent on a 5 series oilpan and an OBD1 wiring harness.
      • euroshark
        • Apr 2006
        • 3491
        M20 heads are cheap, but I still say go with the swap!
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          swap
          • Mot
            45 toting redneck
            • 4018
            Good man, coil packs ftw.
            • 2002maniac
              • 4260
              helicoil it.
              • Slick92GS-R
                • Apr 2005
                • 662
                this happened to my GS-R whle on the turnpike @ 90mph----limped home and i parked it-- since last July-- and have been working on the E30 full time ever since--
                u know what to do -- remove the head--and str8 to a machine shop --that M52 is great if u have daily driver for the down time
                --Hayden--
                '87 325 coupe- Trak Rat
                '93 318is- 4cyl's of fury
                '92 Integra GS-R--yeah, its fast..
                www.G2IC.com
                • 318isbmw
                  • Nov 2005
                  • 2841
                  I agree, helicoil it and start saving for the swap in a bit...
                  • Fidhle007
                    • Oct 2005
                    • 7209
                    I have a grand saved so far, and an M52 already, worth the time perhaps?
                    • Fidhle007
                      • Oct 2005
                      • 7209
                      I can pull the head myself, and if needed I even have a spare M20 head I could use instead, but it just seems like if I'm going to dive into the engine bay that much I really should just get the swap done now...?
                      • blueapplesoda
                        • Dec 2005
                        • 1904
                        doo eeeeeett m52 swappage ftw. Im getting sick of my tickbox m20. btw the m5X/s5x series motors are gonna be the motor to build soon or later, so if you wanted to go big, it shouldnt be a problem.
                        Do eeeet NOW!!
                        • Mossman
                          • Apr 2006
                          • 1961
                          I've never done it but there are helicoil spark plug kits so it's definitely doable an d since the plugs are pretty accessible you shouldn't have to remove anything I wouldn't think. Just gotta hope the metal shavings from boring out the hole don't cause any problems.
                          • psloan
                            • 9815
                            It's a can of worms - do the s52 - it will be off the road for the same amount of time. It took me a week with everything i had to do when i pulled my engine in my 02 to helicoil (ended up replacing the head) a stripped head. However, mine turned out to be a stripped helicoil in a helicoil. Hopefully you wont be so unfortunate.
                            • KangamangusDriver
                              • Aug 2005
                              • 1870
                              JB weld it!!!
                              j/k
                              Sorry to hear brandon!!
                              Time for the Swappage!!!!!!!!!!!!!!
