How much stiffer is the E30 M3 chassis than the standard E30?
  • Joey Link
    drunkest guy at Oktoberfest!
    • Nov 2004
    • 1176
    I'm reading up on the chassis stiffness of E30 325i/is, E30 325iC, E30 M3, and E30 M3 Convertible and how they compare. I'm interested in seeing how they compare. How much stiffer is the M3 than the 325i/is? How much stiffer is the 325i/is than the 325iC? What did they do to make the M3 chassis stiffer?
  • backtrail69
    • Jul 2005
    • 4471
    I don't believe that the M3 is any stiffer than the regular e30s because it uses pretty much all the same basic architecture other than the quarters, fenders, bumpers and roof line/trunklid which shouldnt effect things enough to matter.
    The cabrio is much looser than the hardtops because there is obviously no roof to reinforce the chassis, the rockers are enlarged to help combat this. There might be a stiffer floor pan, but I am not sure.
    If you are only going to buy an M3 because its "stiffer" save your money and just build up a coupe. You will save lots of money and it will handle just as good.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • browntown
      • Jun 2004
      • 3524
      Isn't the windshield a structural member or something on the m3?
      • erik325i
        • Jan 2005
        • 3567
        Yeah, the front and rear windshields are bonded in to provide some more structural integrity. Besides that though, I don't think there is anything else that would make the chassis stiffer.
        -Erik
        • LINUS
          • 2422
          As for that rear window thing, I'd be interested in hearing if it added anything to unibody stiffness, as that whole rear window assembly is somehow joined to the unibody. I see th obvious seam on the roof of mine, and I haven't taken the time, but I do need to follow it down the C pillar, as I get a little water dripping into the trunk on the driver-side inner fenderwell.
          Anyhow, that window is bonded to a part that isn't directly the unibody, it's not even steel IIRC.
          It's not how you handle the good times, but the faith you keep in the bad that defines you.
          • AdamF 88iS
            • 2051
            The rear window doesn't do anything on M3s. The front glass being bonded makes a difference, though.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • george graves
              • 19998
              So then the question is, can we "upgrade" to bonded glass? Or is it a different windsheild surround and not a different glass part?
              Originally posted by Matt-B
              • Massive Lee
                • Sep 2006
                • 6785
                Regular e30s can use the thinner M3 bonded windshield and gasket. It is only twice the price. And because the glass is a structural element, it sometimes crack if the shell gets stressed/hit.
                massivebrakes.com
                • Jean
                  • 18228
                  Sounds like a great mod ! not lol
                  • 808BMW
                    • 2910
                    If I had money and wanted more chassis stiffness, I'd get a well built cage.
                    • LINUS
                      • 2422
                      And to prove the supidity of some people (not meaning you at all, Lee), a standard e30 windshild & gasket fit an M3 as well.....sadly I know this because this is how my car sits until I can afford a respray. At least I don't have the cowl rust problem.
                      But yes, some P.O. got someone to shoehorn a standard screen in with a standard gasket. Idiots.
                      • jmarch
                        • Oct 2004
                        • 163
                        These cars aren't what I'd call rigid and the difference between an M3 and 325is is negligible. Jack up one end of either and open the door and you'll see what I mean. When I jack up one end of my 993, the whole side of the car rises.
                        1995 Porsche 993 6 speed
                        2001 BMW M3 6 speed - DD
                        2001 BMW 530iA Sport - Hers
                        2005 KTM 450EXC 6 speed
                        Gone:
                        1988 BMW M3 2.5 EVOIII Clone
                        1988 BMW 325is x2
                        1985 BMW M635CSI 286hp
                        2001 KTM 400MXC
                        • AdironRider
                          • Dec 2004
                          • 3491
                          Noone ever said a basic e30 is comparable to a porsche.
                          Back to my roots
                          • ping65810
                            • Sep 2005
                            • 366
                            HAHA My thoughts exactly. e30 was a mass produced compact semi-luxury sport saloon, not a Porsche. e30s are ridgid compared to lots of stuff. When I would offroad my Ranger, with one front wheel on a rock, u couldnt open either door! Now thats lack of ridgidity
                            01 325Ci
                            87 325iS w/ M30B35 swap
                            • jmarch
                              • Oct 2004
                              • 163
                              Hey, they're way better than my old E21. I couldn't even open the door when I jacked one side of the car up.
                              My point was that these cars are flexible enough that any difference between an E30 M3 and "regular" E30 is unnoticeable.
                              Gone:
                              1988 BMW 325is x2
                              2001 KTM 400MXC
