Need some help NOW
    Need some help NOW
    I installed a crach free dash yesterday - and now my obc and tach dont work. What did i mess up or forget to reconnect?
    Also, I installed some new front speakers. The old ones had a ground cable which i just left unattached to the new speakers. Now I'm getting no sound from the front. Whats up with this?
    BTW the cluster is in the car.
      Patrick, I promise that was not a ground wire on the speaker.
      Premium sound has 4 wires connected to the stock mid. 2 in, 2 to the tweeter.
      On the OBC/tach issue, I have no clue.
      GL!
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
        So, if i dont want to use the tweeters just connect the 2 in?
          There is a green plug on the back of the cluster that i can not find wires for - is this the cause of my obc issues?
            'xactly. Look carefully at the speaker if it is a premium. You will see which 2 terminals go to the woofer.
            I cant remember which 2 wires plug into the speaker, though.
            Luke
            Closing SOON!
              From Fred Kims site
              Take the new wiring harness and plug its yellow connector behind the cluster, then wire it through the dashboard and plug the green connector to the back of the OBC. Make sure the black tab is down to lock the connector in place. At the other end of the harness, you will see four connectors (black, green, blue, and white). Wire them down the left side of the dashboard.
              BLACK CONNECTOR: Plugs into the right slot of the door gong and is used for low temperature and maximum mileage features.
              GREEN CONNECTOR: Plugs into the fuel pump connector and is used for the CODE feature. Also supplies a feed to the auxiliary horn (which must be added); not necessary if you are don't want the feature active.
              BLUE CONNECTOR: Plugs into the turn signal stalk and is used for the OBC remote control feature. If youd don't install the turn signal, then you don't need it.
              WHITE CONNECTOR: Plugs into the ambient temperature sensor.
              Continuous For Sale Thread
              323i s50
