wow... that just sucks. sorry man. As everyone else said, if you were drivin home after the work was done at the shop talk to them and tell em what happened. Don't be a dick about it though, be kind and professional. If they give you hard time then you can start yellin at 'em. :D
Caliper go bye bye from carrier...
i say you hit a really deep bump that damaged the carrier and the wheel.
sorry to hear about this. i know it'l be close to impossible to find the same wheel you have now.Comment
no way! I just bought them!!!
Yeh, I'll see if he can help out!
The bump was rather small! I've hit it before because this is the exit I take home!
This is the most disappointing part of it all!
I'm going to see if this can get repaired though.
Thanks, I'll let you know man.
I know, I was thinking about this! I'm glad this is ALL that did happen.
Very good point. I'll give them a call!
I've hit this bump before, honestly I have no choice because of how the exit is designed!
Yes, finding another rim is going to be painful.
Thanks for the responses dudes, I will keep the thread updated.
Currently try to source:
Strut with wheel bearing
Bridgestone Tire
ACT rim ... long shot!
I'm going to contact AC Nico and see if he can be on the look out!
Nope, I went to get a quote and was told to come back around 4!IG: deniso_nsi Leave me feedback here
Rotors will warp if you do not tighten down the lugs evenly and if you do not use the set screw that keeps the rotor on the hub. Also I have been told that you should resurface the rotors when they are new because they can warp on the shelf. I am not sure I believe this because I bought a new pair last year and just cleaned off the protective coating and they worked fine.Comment
Wow Ive literally never seen that......literally.
Mariano
Warped on the shelf? Man that warehouse must have been hot inside.Comment
1989 Bronzit 325ia- Sold
1988 Delphin 327i- Sold
1995 Cosmos M3- CurrentComment
I do not think I would trust anyone that put that wheel back together.
As for SS lines, I have a full set minus one front line. I picked them up from BMP because I had a problem unlike yours. Id kick you the set minus one front line for $40 shipped. PM me and let me know!Build your own dreams, or someone else will hire you to build theirs!
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Patrick @ BMA.
I'm definitely not blaming him, because he's the man! Hopefully he can get me replacements!
Sent them an email! Thanks!its a LONG shot, but wheel collision center out of bath, PA might be able to do something with that rim. they work wonders, ask me how i know.
http://www.wheelcollision.com/
Thanks dude, I will let you know!I do not think I would trust anyone that put that wheel back together.
As for SS lines, I have a full set minus one front line. I picked them up from BMP because I had a problem unlike yours. Id kick you the set minus one front line for $40 shipped. PM me and let me know!IG: deniso_nsi Leave me feedback here
