Help. Lost Tach, Fuel, and Temp. Fuse #10 blown
  • VROOMCP
    • Apr 2007
    • 197
    I thought it was a bad headunit install, but I had some guys check it out and they dont think it is. I've replaced the fuze (7.5) and it takes a few seconds before I lose my guages.
    Any suggestions? For reference, it's a 90 325is.
    Thanks,
    David
    Looking for my next E30. Have one? Call or text me (805) 340-3284 or email me at: dclrod@gmail.com
  • LikeCDoos
    • Jan 2004
    • 2522
    Thanks,
    David
    Sounds a bit like the SI batteries in the cluster, I could be wrong though.
    • VROOMCP
      • Apr 2007
      • 197
      Even the AC blower is out. Hmmmm
      • Erick
        Official R3V Drifter
        • 11169
        Thanks,
        David
        When did it start happening? Right after the new headunit? The radio is directly related to fuse #10, and if the fuse goes out, obviously everything else that goes through it also goes out (namely the tach and blower).
        Double check the headunit install.
        ..::Support FullOpp::..
        FullOpp Stickers for sale!
        Feedback Thread
        • backtrail69
          • Jul 2005
          • 4471
          Definately sounds like some non covered wires that are shorting somewhere..
          :: PNW Crew ::
          '87 325 4dr, '74 2002
          • VROOMCP
            • Apr 2007
            • 197
            The headunit remains on - is that normal?
            David
            • Erick
              • 11169
              Shouldnt be. When my #10 went, so did my radio. Is the radio wired to the original 12v source? If not, whatever happened to that end? If there's a short there, then that'd explain it.
              Mind you, I'm no electrician. Just giving my best guess.
              Feedback Thread
              • e30sd
                Fistee
                • Jan 2004
                • 5517
                check the reverse light switch wiring.
                • Jbpka06
                  • Feb 2006
                  • 551
                  Mine was the reverse light switch wire. My radio still works with fuse 10 blown.
                  • SchnellerVert
                    • Sep 2005
                    • 3948
                    Dreaded reverse lights rearing it's ugly head. Unplug the power wire switch and put new fuze in, fix wire and viola back in business.
                    This should be a permant stuck topic. This one is mentioned over and over yet the Search button is never used.
                    • BENdashdash
                      Tom is not my friend
                      • Aug 2004
                      • 2506
                      just do what i did and pull your dash ...to find that your head unit shorted.
                      • VROOMCP
                        • Apr 2007
                        • 197
                        Definitely a short somewhere. It stopped doing it..... Thanks.
                        This should be a sticky!
                        • Erick
                          • 11169
                          It stopped "doing it?" How did you fix the short? If it's still there, its bound to happen again.
                          Feedback Thread
