Driving problem.
  • e30lyf
    • May 2007
    • 4516
    Driving problem.
    Every time i was in 1st gear or 2nd gear. When i release the gas pedal. The car stop right away. So my passenger get dizzy, Supossed to be car still rolling. Unless i press the clutch it wont do that. Any idea why happen like that? Thanks
    __________________________________________________ ____________
    Fercy
    - Fercy -
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
  • fwappy
    • Feb 2007
    • 362
    Not sure of the answer, but very interesting sentence structure. However, I'm sure someone will have the solution.
    "If I were filthy rich I'd still drive my E30."
    • whiltebeitel
      • Apr 2007
      • 2098
      What speeds? 2-5 mph? 10-20? If you are just creeping, then your car must be stalling, possibly due to making little power, or your brakes are dragging somewhat. This is all I can guess right now.
      '89 325i track sloot
      '01 530i daily
      -Enginerd
      • Mike325
        • Mar 2006
        • 3685
        Sounds like a bad poem.
        Originally posted by Kershaw
        • brandondan1
          • 1091
          I have the same problem (if I understand your post correctly). Say you're going 10mph in 2nd gear and u let off the gas. The car clunks and jerks backwards, which pushes you forward in your seat. or are you experiencing a constant bucking?
          I was thinking it's time to change the differential fluid with redline, as it probably has the same fluid it came with 20 years ago.
          91 318is
          • MikeE30325i
            • 2356
            i think that when this is happening your car is at or close to idle, so when you let off the gas, with the clutch still engaged, your car (especially if it is an "i") is struggling to keep the car rolling.
            that is why it clunks, your diff fluid is probably fine, and will have no effect on this, simply because the engine is struggling to stay at idle, since in 2nd gear at 10 mph you are at about 700-800 rpms. which is right above factory idle. and its hard for the car to keep moving.
            • s0urce
              • Dec 2004
              • 2933
              Use your clutch?
              tasty
              • brandondan1
                • 1091
                I didn't have exact figures, but 10mph in 2nd in my car is still around 1100rpm. I can replicate the problem even at 20mph in 2nd so I don't know why the car would be struggling to stay alive.
                Shitty fluid will cause clunks. Anyway, just throwing an idea out there.
                91 318is
                • euroshark
                  • Apr 2006
                  • 3491
                  Shitty fluid could be a small part of the problem, but more likely the diff is actually worn out of spec, or your fuel injection is running too lean.
                  I say lean because at idle if you lean it out you can get hiccuping and surging, and in my E28 if I lean out the AFM more than about 2.5 or 3 full turns from full rich, I get the exact problem you are describing - low speed, low gear jerking. Richen up the AFM and see what happens.
                  You may also try the Bosch Design III injectors. I added those plus a 3.0 bar fpr to my 533i about 8 months ago and it drives super creamy smooth, and my fuel economy increased!
                  • e30lyf
                    • May 2007
                    • 4516
                    We flusch the brake fluid. New rotor & brake pads. 1st gear 10 to 15mph when i left gas off the car stop. weird. Im not sure about fuel injection.
                    - Fercy -
                    Santa Clarita, CA
                    www.BimmerHeads.com
                    • MikeE30325i
                      • 2356
                      WTF are you saying? complete english sentences please!
                      and do some other things that these people are saying, like bad diff oil.
                      • Jesse30
                        • Jan 2007
                        • 3936
                        dude, use your clutch. it sounds like your expecting it to keep driving itself with the clutch engaged at idle.
                        english. use it.
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          The reason a car would buck is "lash" in the drivetrain. Gears don't mesh perfectly, especially in older cars such as ours. Combine all of that space, and the drivetrain will act as a spring of sorts and the car will jerk at low speeds. This is compunded by the compression braking of the engine. Solution: use the clutch and don't let rolling RPM drop too far below 2000 RPM on deceleration.
                          Project M42 Turbo
                          • MikeE30325i
                            • 2356
                            that has to be one of the most informative first posts i have ever read... good job.
                            • Fidhle007
                              I can fly, motherfucker
                              • Oct 2005
                              • 7209
                              Since the creation of the Internet, the Earth's rotation has been fueled, primarily, by the collective spinning of English teachers in their graves.
                              '89 325is S50 Track Montser
                              '04 X5 Daily/Tow Vehicle
                              http://www.avarestoration.com
                              http://www.myspace.com/brendanfiddle
                              Click here if you want to be my zombie slave...
                              http://www.youtube.com/user/Fidhle007
