When you stuff an S50 3.0 crank in a 2.8 aluminum block, what is compression?
When you stuff a S52 3.2 crank in a 2. 8 aluminum block what is compression?
How difficult will it be to build up a stroker? I have a complete 2.8 block in my yard. Is swapping in either the 3.0 or 3.2 crank a simple procedure? Will I have to change/modify anything else?
I want to keep this as simple as posible which means using as much of the parts I have as possible.
