First parking ding ever. fixed.
  • redbull 325is
    • 7471
    It finally happened, after years of never getting a parking ding, i finally hit something yesterday with my pristine 318ic :-(
    This is basically what I hit:
    My street (at my new place, not the place pictured) is lined with these to prevent cars from parking on the actual side walk. Since I had my top up (ie: foggy rear window) instead of my hard top I couldn't see well and bang.
    - About 2" across and 3/4" deep..
    Well, I was not in the mood to take this bullshit, so i fixed it.
    About $100 of materials later:
    (Mautritiusblau paint, primer, black paint, bondo, various grit sand paper (230->600) and two body shop hammers)
    Removed bumper and tail light and started to straighten out the ding. trick is to not use big hammers or anything without a rounded edge/damper or else you will make a crease in your working area)
    I applied two coats of bondo to get the desired smoothness.
    -Tip 1: Don't make alot of bondo at once, it dries quickly
    -Tip 2: Worry first about shape then worry about smoothness ( a wooden block can help you acheive this while sanding)
    I sanded with 230 grit and then 300 grit making sure to to scuff up too much surrounding paint.
    Next i took all the taping off, cleaned the area with [edit] acetone [/edit] (nail polish remover...) and retaped a slighly larger area for the primer. This whole area was smoothed out using 400 grit sand paper.
    -Tip 1: Small even coats prevents orange peel
    -Tip 2: A light scuffing between coats is a good idea, but make sure the primer is dry!!
    Clean off area using damp cloth and spray paint coat. remember, paint hides nothing, so if it doesn't look mint right now, it never will.
    -Tip: again light even coats does the job.
    Also took this oppertunity to paint my flat black euro LM bumper (mid process)
    Finally, take the tape off and notice how crappy it looks (not pictured). There is litterally a ridge between the newly painted area and the old painted area.
    To fix this you must sand this "ridge" with 400 grit sand paper. I used my finger wrapped in sand paper to really get on it. Your final result must feel smooth with your nail (scraping from new to old paint.)
    Once you've acheived this, wetsand the whole deal with 600 grit (again you are doing the main working area + 1 Inch around taped off from the rest of the car.
    The Idea is to cover up any remaining marks with paint while not overspraying on the old paint and thus getting another "ridge". I used a fading style to grade from on paint to another. Luckily my paint matched up color really well, but texture was off. (www.paintscratch.com carries BMW paint for the N/A market)
    Reassembly before polish
    Polish: Use a good product and make sure everything is dry!!! Don't need to use a powerdisk unless you are in a very visible area!
    Finished Product 1
    Finished Product 2
    Last notes:
    1. Always overdo each step, don't expect the next step to make it look that much better. Get it as good as you possibly can at each level.
    2. I was working around gravel... be careful for dust, i got lucky
    3. Make sure you have everything before hand...
    4. Paint rarely matches up but you can usually make do if you cut it off/wetsand/blend it nicely.
    5. Beer helps too.
    Cheers!
    Julien
    Build Threads:
  • Jscotty
    • Jan 2007
    • 2285
    That looks like you copied that straight out of the Chilton's bodywork book....especially the pic of your tools and supplies laying on the ground.
    BTW, I like those wheels. What did they come off of and are they 5-bolt?
    • adept
      • Feb 2006
      • 425
      Awesome job!!!
      • Erick
        Official R3V Drifter
        • 11169
        Hahaha what a horrible ass driver.
        Jokes... :p Definetly nice work for the materials you used.
        ..::Support FullOpp::..
        FullOpp Stickers for sale!
        Feedback Thread
        • MikeE30325i
          • 2356
          wow, that is amazing! really fixed that right up!
          • 87-325ic
            • Apr 2006
            • 1198
            looks good, but what the hell are you doing in france?
            • AndrewBird
              The Mad Scientist
              • 11898
              You used MINERAL SPIRITS to wipe the area down?!? Mineral spirits is a petroleum based solvent and should NOT be used with paint (except to thin specific types of paint). Finger nail polish has acetone in it. Are you sure you didn't mean acetone?
              Looks good though. Nice write up too. I'm surprised you only went down to 600 grit. I would have thought polish wouldn't take out the scratches left behind from 600.
              • redbull 325is
                • 7471
                Yes, i meant acetone, oops. I would have gone to 800 if it were necessary, but i was happy with the results as is..
                thanks for the input guys!
                Julien
                Build Threads:
                • matthugie
                  • Mar 2004
                  • 1810
                  I'm disappointed in you julien. Having been in your car when you drove between two barricades (slat style) that were set such that a car could not be driven through, and the only reason you could fit through was that the side mirrors fit between the slats, and you even went through at an angle. then you do this. and what beer did you drink btw? i don't think they have PBR or Steel Reserve over there.
                  88 325is - S52 powered
                  Originally posted by King Arthur
                  We'll not risk another frontal assault, that rabbit's dynamite!
                  • Silence*
                    • Feb 2007
                    • 294
                    NIce job! About how long did it take you to do?
                    • FredK
                      • 14759
                      They're four lug and they were an optional wheel on US E30s.
                      • BCMike
                        • Oct 2005
                        • 117
                        Excellent Julien, it's posted efforts like this that stimulate the rest of us to take on these jobs instead of simply paying the shop.
                        Let's go exploring!
                        • redbull 325is
                          • 7471
                          i was drinking heineken :hitler:
                          Build Threads:
                          • -Javier-
                            • May 2007
                            • 382
                            Nice job on that fix man.
                            Finished Product 1
                            Finished Product 2
                            Last notes:
                            5. Beer helps too.
                            Cheers!
                            Julien
                            • 8atman
                              • Apr 2007
                              • 492
                              Nice, are you sure you didn't purposely hit it just to show off your body workin skills?
                              Nice job man.
