Going to look at a car, Odometer inacurate, Still good?
  • JamesE30
    • Feb 2007
    • 2092
    I'm going to look at a '84, 4 door 318i today with a friend,
    She loves everything about the car, my only concern is that the guy pulled out the "previous owner" line.
    Apparently the previous owner reconditioned the entire engine and replaced many of the instruments, in turn, the odometer only displays the 3700km since refurbishment.
    "ENGINE WAS RECONDITIONED BY PREVIOUS OWNER, MOTOR HAS 3,700 KLMS ON IT SINCE THEN. SORRY WE DO NOT KNOW THE ORIGINAL KLMS ON THE CAR AS THE PREVIOUS OWNER REPLACED ALOT OF INSTRUMENTS ON THE VEHICLE"
    Q1:
    Is there a way of determining the exact or rough km's on the engine without extensive mechanical work?
    Q2:
    supposing this ^ is not an option, what signs should i look for to determine the engines quality / life?
    Q3:
    Way off topic ...sort of,
    Is Achatgrun-metalic a rare colour?
    Ive never seen it on another car except mine and the one above... ?
    Thanks guys
    R.H.D
    M-technic I club
  • Maluco
    • Oct 2005
    • 6572
    Don't go....
    • James Crivellone
      Head Janitor
      • 6304
      Its a 318i, the motor costs about 20 bucks, or a 6 pack of beer.
      I would not worry about it.
      • JamesE30
        • Feb 2007
        • 2092
        thats great,
        thanks so much for you input guys,
        The car is not for me, it is for a female friend who wants an economic, cheap, practical car. She will not be dropping clutches or planting the accelerator,
        so if anyone could help i would appreciate it very much.
        Thankyou!
        R.H.D
        M-technic I club
        • Maluco
          • Oct 2005
          • 6572
          thats great,
          Thankyou!
          It's a 23 year old 318. Like James said, parts will be cheap. Work depends on who does it but it should be fairly simple. Everyone pretty much expects to invest some money and work into the E30s they purchase unless of course you are buying something proven.
          http://www.r3vlimited.com/board/show...ghlight=buying pertains to a 318is but it looks pretty thorough to me.
          "If you are thinking of buying a 318is follow this list of suggested items to check. Many are obvious, but may save you time and trouble in the future. Hopefully it will help you to avoid the hacked cars out there, as most 318is will probably require some work given their age. I have listed a number against each to indicate the potential seriousness (=cost!) to help you gain an insight into the faults. 1= Serious fault 2=Of concern 3=Minor fault."
          Engine
          Check for ticking noise coming from valvetrain, especially when hot (1)
          Check for a noisy timing chain - a hissing noise esp. around 3-4,000 rpm (2 if slight, 1 if severe)
          Check for a replaced BMW OEM profile gasket (1)
          Check for a blown or blowing head gasket (1)
          Check service history (preferably BMW but a well documented history is better than none) (2)
          Check oil type used (synthetic is best, good brand second best) (2)
          Check for smooth reving up to 6250rpm (1)
          Check for blue oil smoke from exhaust on both cold startup and overrun (1)
          Check for steady idle at ~850rpm, both hot and cold (2)
          Check for water leaks (evidance of antifreeze around engine bay) (2)
          Check for overheating (1-2)
          Check condition of spark plug leads - they are expensive (2)
          Check condition of vacuum hoses around inlet manifold (3)
          Check for significant oil leaks from rocker cover (3), head gasket (1), timing covers(3) and oil pan (3).
          Check for excessively noisy injectors (1)
          Check for a ticking around the inlet manifolds (x2). Inspect for any signs of manifold cracking (2)
          Check for failing exhaust maifold gaskets or manifold, detectable by a load related ticking. (2)
          Check for fuel leaks around injectors (2)
          Check for a failing fuel pump. A slight hum should be noticeable from inside and outside the car but it should not be excessively noisy. You should not be able to hear over the cars' noise past ~40mph. (1)
          Gearbox & Transmission
          Check for a relatively smooth and short gearchange. Be aware than many 'boxes are notchy when cold. (1)
          Check gear linkage for freeplay (2)
          Check synchro in all gears (except reverse) (1)
          Check history of oil change in gearbox and differential (ideally every year although ever 2 years is satisfactory) (2)
          Check gearbox for excessive leaks. Slight weep from the rear is normal (2)
          Check differential for leaks. Some weepage from the driveshaft sides is normal (2) but a pinion oil seal is more problematic (1)
          Check guibo (flexible disc in the driveshaft) for cracking around the bolt holes (2)
          Check both CV joints on both halfshafts for noise and damaged boots (2)
          Check for vibration when driving. If the car vibrates from 5
          60-80 mph/100-140 kph the driveshaft could be out of balance or the guibo worn (1)
          Check for differential whine above 50mph (1)
          Check for gearbox whine, especially if evident in all gears (1)
          If mileage is over 120,000 miles/200,000 kms, enquire if the clutch has been replaced. If the car has done a lot of town driving it may be due (1)
          Check for a very stiff clutch pedal (1)
          Check for a very soft clutch pedal (2).....
          .....Check clutch slave and master cylinders for evidence of leaks. They last about 10 years or 80,000 miles (2)
          Brakes
          Check for regularily changed brake fluid, DOT 4 or better (3)
          Check for front and rear disc/pad wear (3)
          Check for disc condition - scoring, cracking or pitting (2)
          Check for damaged flexible hoses to calipers (2)
          Check metal pipe around the back axle, especilally over the subframe (2)
          Check for caliper failure/seizure (1)
          Check if the car vibrates while braking the discs could be worn (2)
          Check for damaged pad wear sensor at front left and rear right calipers (3)
          Check for failing mastercylinder (with the engine running, press brake pedal firmly and watch for it to creep down) (1)
          Look for leaking parts by checking brake lines, especially at the master cylinder, at each caliper, ABS pump and at each end of the flexible hoses (1)
          Wheel and tyres
          Check all wheels (don't forget the spare) for kerbing, damage and corrosion (1)
          Check all wheels for bolts (3)
          Check all wheels for centre caps (3)
          Check all tyre for wear and evenness (2)
          Check for the same tyres on each axle (3)
          Check brand of wheels and tyres - it can give an indication of the care lavished (3)
          Suspension
          Check rear suspension subframe bushes for wear (listen for a clonk when acclerating hard in first and watch for a wandering during high speed turns) (1)
          Check rear trailing arm bushes (1)
          Check wheel bearings for noise or roughness (1)
          Check rear damper upper mounts for noise (2)
          Check all anti-roll (sway) bar bushings for cracking (2)
          Check front contol arm (wishbone) and balljoints freeplay (2)
          Check front control arm bush for cracking (2)
          Check steering rack freeplay (1)
          Check power steering pump for noise and leaks (1)
          Check steering rack rubber gaiters for cracking and leaks (2)
          Check inner and outer track rod ends for freeplay (2)
          Check tyre wear pattern - a slight bias towards the centre of rears and inside of fronts is normal (2)
          Check dampers (bounce and leaks) (2)
          Check rear damper upper mounts for movement (3)
          Check for a level car from behind (1-2)
          Check for a level car from the side; note that the front sits lower (1-2)
          Check front top strut mount for exesssive freeplay (1)
          Check the car does not pull or wander (however bigger tyres may "tramline" over ridges and painted lines (2)
          50-70 mph/80-120 kph the front control arms, etc. could be worn (1)
          Interior
          Check seats for operation in all directions (1)
          Check seat hinges and springing for wear (1)
          Check seat frame (especially the backrests) for breaks (1)
          Check condition of seats, carpets, gear knob and pedal rubbers - they should verify the cars mileage (2)
          Check rear demister works (2)
          Check air conditioning blows hot and cold when engine is fully warmed up (1)
          Check that the wiper, indicator and light switches work (2)
          Check windows for operation (2)
          Check central locking for operation (2)
          Check sunroof operation (1)
          Check for operational instrument guages (2)
          Enquire if SI board batteries have been changed in the last 5 years - they last between 5 and 10 years (2)
          Check door cards for damage or wear (2)
          Check screws around instrument cluster. If worn, enquire why - the car may have been clocked (1)
          Check footwells in boot for evidance of damp or rust (2)
          Check carpets for dampness (2).
          Exterior
          Check general headlight alignment (2)
          Check headlights & lens for damage (3)
          Check hydraulic headlight adjusters if fitted (2)
          Check panels gaps are equal around the car (1)
          Check bonnet fit (1)
          Check for a straight line along the crease down the side of the car (1)
          Check for an original front valance (1)
          Inspect the front suspension turrets, jacking points and suspension mounting points for signs of rust (1)
          Check for evidance of oversprayed paint under window seals, around lights, behind bumpers, behind radiator grill, on front valance/spoiler, exposed wiring looms, gutters, under door handles, etc. (2)
          Previous Owner
          Investigate the type of driving previously undertakem (urban or rural) (2)
          Assess the care given to the car by the previous owner (2)
          Assess what modifications (is any) have been made to the car and what their purpose was (2)
          Assess the level of maintenance given (1)
          Assess the attitude of the previous owner (1)
          Check that all paperwork is correct and match chassis and engine codes to the log book. (1)
          General Other Checks
          Check for road tax expiry date - if it is a long time in arrears then the car may have been sitting idle / unsaleable - WHY?
          Check road tax books for frequency of renewal.
          Check chassis, engine numbers and body colour against documentation.
          Check the toolbox, jack. brace (wheel spanner) and warning triangle for condition.
          With a multimeter, check the battery voltage reads above ~12.2 volts. With the engine running this should rise above 13 volts.
          • thectrlguy
            • Apr 2007
            • 1042
            How much is said car? and what's the body like? Like the others said, parts are cheap.
            • kencopperwheat
              King of Kegstands
              • 14396
              M10s are pretty bullet-proof with routine maintenance.
              Originally posted by Gruelius
              • 808BMW
                • 2910
                Go for it. Almost every e30 I've seen has a broken odometer anyway. (I've had 3 e30's, 5 clusters, all broke eventually)
                • JamesE30
                  • Feb 2007
                  • 2092
                  they want $3.5g for it, which here in AUS is a bit of a steal,
                  its achatgrun metalic,
                  4 door
                  318i
                  manual
                  alloys
                  Very good condition everything,
                  new black/grey interior,
                  sports exhaust
                  ppioneer sterio
                  look promising...
                  small pic:
                  (private sale not dealer)
                  edit: Maluco: thanks for your responce.
                  appreciate it.
                  R.H.D
                  M-technic I club
                  • E30 Reaktionär
                    Site Manager
                    • 14451
                    All i can say is take it for a test drive. And is yours a right hand side drive car too? Like that one.
                    1992 BMW 325iC
                    1978 Chevrolet Monte Carlo
                    • JamesE30
                      • Feb 2007
                      • 2092
                      Of course a test drive is in order, im just not sure what to expect from a 318...
                      And yes they are both right hand drive
                      R.H.D
                      M-technic I club
                      • blueapplesoda
                        • Dec 2005
                        • 1904
                        expect slowness
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          You would know. ;)
                          • Mr Deagle
                            • 1121
                            Even if you cease all maintenance, they are still bulletproof. Just add oil.
                            • Maluco
                              • Oct 2005
                              • 6572
                              That's 2,931 US dollars. Here that would be considered stealing from the buyer. Looks good from the outside though. (I guess pre 89s in Australia came with "tucked" alum bumps)
