Maf Conversions - Where ?
    Who does maf conversions via mail order in the USA ?
    Is there any at a reasonable price ?
    Cheers.
    I believe BMP has one but its not cheap.
    Driving is the only way to go faster....
      The Smt-6 is probally the cheapest proven setup here in the U.S. I know of one setup cheaper but no one has tried it yet to proove it will work, by the numbers it will but you never know.
      85 325e 2.7 ITB'd stroker
        i don't see any reason it couldn't be done with an apexi s-afc, if like me, you only have 91oct gas available and don't want to f*** with your ignition timing past what your chip will do.
        past:
        1989 325is (learner shitbox)
        1986 325e (turbo dorito)
        1991 318ic (5-lug ITB)
        1985 323i baur
        current:
          Right. Its a Split Second unit. You can go right to the split second website if you just want bits and pieces of the BMP kit (like, if you wanted a different A/F ratio meter).
          But hey, while you're at it, spend another $2k for mulit throttle body setup ;)
          A great pleasure in life is doing what people say you cannot do- Walter Gagehot
            Apexi will work also, the system I'm looking at is around $120 but I'm not sure if I want to spend the money to test it and find out.
