Swap Cost Comparisons: M30vsM50vsS50vsS52
  • der affe
    Technical
    • Dec 2005
    • 8452
    #46
    thanks again!
    so i guess the ultimate m-30 would be a 91-92 s-38. what kind of hp are you looking at in stock form?
    has anyone tries the IE m-30 headers yet?
    are they available? good fit or crap?
    • Ahheck01
      • Aug 2004
      • 185
      #47
      Originally posted by der affe
      thanks again!
      the s38 is not an m30. They're two separate engine codes.
      -Evan
      1992 525i 5speed: Sold :: 1996 328i 5speed: Sold :: 1997 540i 6speed: Sold :: 1995 M3ti 5speed: Sold :: 1997 328i 5speed: Sold ::
      • whiltebeitel
        • Apr 2007
        • 2098
        #48
        S38's are 315 hp stock, but they are a sh*t ton of money for rebuilds, which they need after every, what, 100k miles?
        '89 325i track sloot
        '01 530i daily
        -Enginerd
        • euroshark
          • Apr 2006
          • 3491
          #49
          Evan, they aren't the same engine, correct, but they are the same family... Cut the guy a little slack!
          der affe: Just to clarify, M30 headers only fit the M30, and all M30s are 12 valve motors. S38 headers fit the S38 only, and all S38s are 24 valve motors.
          The 3.5 liter S38 found in the E28 M5 and E24 M6 makes 256hp in US spec, or 286hp in euro spec. The 3.6 liter S38 found in the E34 M5 makes 310 - 315hp depending on your source. The 3.8 liter S38, the largest 6 cylinder BMW motor ever produced, makes 340hp and was found only in euro M5s with the Nurburgring package.
          • der affe
            Technical
            • Dec 2005
            • 8452
            #50
            ok that's out of the question then.
            on another note Wolf now has a plug and play stand alone with 88-91, 3 series specific harness ....only $2200.00. just incase anyone was wondering.
            • whiltebeitel
              • Apr 2007
              • 2098
              #51
              Sorry If I came across as harsh or short. My sis has a ricer e34 (I tried to stop it) and I really love the M30. If I didn't AX, I would do the swap.
              '01 530i daily
              -Enginerd
              • E30 Cabrio
                • Oct 2006
                • 1954
                #52
                Does any Tuner make a California smog legal turbo kit?
                Looking to run low boost ( 5-7 lbs.) on a low miles, stock motor.
                1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
                Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
                Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
                • euroshark
                  • Apr 2006
                  • 3491
                  #53
                  California legal is a whole other issue... I would expect the answer to be no, since there are only two M30 kits that you can buy new anymore, the TCD kit and the other guys kit which is more expensive and appears to be not as good... You could always call Todd at TCD however.
                  turbochargingdynamics.com is available for sale! Check it out on ExpiredDomains.com. turbochargingdynamics.com is in high demand, secure it today!
                  • der affe
                    Technical
                    • Dec 2005
                    • 8452
                    #54
                    does the trans you need to use for the swap, suffer from the "lay shaft bearing noise" that the e-30/m-20 5 speeds have (sorry i don't know the number of the getrag trans's)
