1987 325i timing belt snapped
  • amdspitfire
    • Mar 2006
    • 254
    I got a 87 325i, the timing belt snapped at just 105k (previous owner decided not to change it).
    How do I get this thing running again ;)?
    (edited to get to the point, pics on post 15)
    (edit #2, post 17)
  • atomic
    • Jun 2007
    • 5691
    I cant think to many choices
    • Jscotty
      • Jan 2007
      • 2285
      Do the M50 swap. Thats REAL racing.
      • amdspitfire
        • Mar 2006
        • 254
        and run in a modified class?
        • BeirBrennerE30
          • 2740
          Yes that would be REAL racing.... hopefully you woundnt get lapped in the first lap. Dont enegine swap an e30 for racing and expect it to be competitive without a LOT of money... depending on the engine you choose you would probably be in C-mod..
          e30sport.net
          '06 M3 Competition - 6-speed
          '97 Range Rover Vitesse
          • amdspitfire
            • Mar 2006
            • 254
            will it be competitive in stock class? I'm new to racing and dont want to build a beast just yet.
            • PrinceE30
              • 282
              Spec E30 is where its at. Rebuild the engine, cage it and go racing! (oh yea, and get your NASA license)
              Randall Prince
              http://www.rp1.us/ Used Cars
              • amdspitfire
                • Mar 2006
                • 254
                ok, I got the car and took some pics, one of the rocker arms cracked off, where do I start from here?
                • StereoInstaller1
                  GAS
                  • 22679
                  Pull the head off (TAKE PICTURES!) and have it tested for cracks, leaks, etc.
                  Have it surfaced, replace necessary parts, re-assemble.
                  See how it performs, go from there.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    ... it to be competitive without a LOT of money... depending on the engine you choose you would probably be in C-mod..
                    Uhhh. Let's start by checking what are the other cars in C-Mod. Oups. Mostly e36 M3 monster cars with mega brakes, mega roll cages and mega engines, running on mega wheels with full slicks. And mega budget. The little e30 will be eaten alive. Not a good idea. Racing is not about big engines in small cars. It's about balance.
                    So, first step is to pop the head and see the damages to the pistons, valves and combustion chamber. Then see what you have to do...
                    Lee
                    massivebrakes.com
                    • amdspitfire
                      • Mar 2006
                      • 254
                      Lee
                      So the work begins, time to learn how to take the head off ;)
                      • Rigmaster
                        • 3464
                        +1
                        Don't do an engine swap and then plan on racing- you'll be frustrated and disappointed unless you crap $1000 bills and are a gifted driver.
                        Spec E30 is the way to go with a car like that. Hopefully the head is salvageable- but do what others have suggested and pull the head, have it checked out by a competent machine shop, then either reinstall the "rebuilt" head and run the car, or install a good used M20 and run it.
                        check www.spece30.com for more details on SpecE30 racing.
                        Bret.
                        • Massive Lee
                          • Sep 2006
                          • 6785
                          The rocker has snapped because the valve was pushed by the piston and it forced the rocker arm. Chances are that you have several bent valves. It can be more economic to find another head. Anyway, by the look of the gunk in your head, it lloks like the engine may need a little clean-up too.
                          massivebrakes.com
                          • BeirBrennerE30
                            • 2740
                            Lee
                            That was my point. I think you missread my post.
                            e30sport.net
                            • amdspitfire
                              • Mar 2006
                              • 254
                              got almost everything off minus the fan/timing belt related items. Will pull it off quick once I get a 32mm wrench.
                              The valve on the right side is the one that broke the rocker arm, can anything be told from this pic?
                              What do I do once valve cover is off?
