sunroof leaking
    sunroof leaking
    Hi, my sunroof is leaking. any suggestions what to check? i checked my bentley manual which says remove the clips in the front after opening the sunroof 1/4 of the way to remove the panel but i cant find it. any help will be appreciated.
    Open the sunroof and at each corner at the front there will be two holes. These are the drains. Take some water and pour it down these drains. There are also ones at the back. Check to see that the water is actually going down these and at a good speed. The wayer should come out a few seconds after going down the tube. If they are backed up, hey could cause a leak. Where exactly is the water coming in?
    Originally posted by Kershaw
      The water is coming in from the front right portion near the corner. dripping from the panel. if the tube is clogged, how do i clean it? how will i remove the panel? i cant see the clips the manual is reffering to. thanks.
