cleaning inside of ellips...
  • monty
    • Feb 2007
    • 665
    Does anyone know of a good way to clean the inside of ellipsoid
    headlights, mainly the high beams? There is no way of getting a
    finger into the high beam to wipe it. Any ideas?
  • PiercedE30
    • Apr 2005
    • 4220
    brake/carb cleaner?
    My 2.9L Build!
    • BeirBrennerE30
      • 2740
      how did they get dirty? putting things into or pouring thing in your ellips are the best way to ruin them. I found that out the hard way
      e30sport.net
      '06 M3 Competition - 6-speed
      '97 Range Rover Vitesse
      • golde30
        • 11464
        also dont wipe the reflective chrome surface very hard, it will wipe rite off.
        IG: @Baye30
        • monty
          • Feb 2007
          • 665
          The lights are smoked German Hella's. The glass isn't smoked, the part that is normally chrome is black. This inside of the glass has a film on it like the bulb burnt out and left carbon on it. I took the lights apart so the bulbs and stuff are all gutted.
          • Brew
            • 3060
            I've got the same crap on the inside of my smoked hella highs... it'd be nice if there was an easy fix, otherwise they're staying like that until I wreck this car.
            '91 318is
            • E30 Reaktionär
              Site Manager
              • 14451
              Mine is like that in the highs of my euro ellips. also.
              1992 BMW 325iC
              1978 Chevrolet Monte Carlo
              • monty
                • Feb 2007
                • 665
                WTF? Something needs to be done about this and i'm gonna finger it out
                • DarkWing6
                  • Apr 2004
                  • 7144
                  QFT
                  Did this a bit with one of my fogs.
                  • DarkWing6
                    • Apr 2004
                    • 7144
                    I guess you could disassemble them taking off the lenses etc. That would allow you to clean the elipsoid with a glass cleaner. I haven't messed with headlights much, so I couldn't really tell you where to start with all that.
                    • dlmpsy
                      • Sep 2006
                      • 189
                      My Hella high beams (non-elipsoids) have a slight gray film on the inside (a little foggy looking). I sloshed around some water inside the light...no luck, I then tried glass cleaner, later alcohol, CLR, and acetone. Nothing has worked. I stopped before I messed them up.
                      • redbull 325is
                        • 7472
                        you gotta stick um in the oven to take the lense off.. no joke
                        Build Threads:
                        • monty
                          • Feb 2007
                          • 665
                          Have you done this? 325 for 20 minutes? How do you break them apart then re-seal?
                          • dlmpsy
                            • Sep 2006
                            • 189
                            I believe you have to warm them up until the rubber sealant starts to get soft (not certain about the temperature), then use a knife to cut around the lens. You then re-seal them (probably a windshield type sealant).
