Need some door/lock help----badly.
  • psloan
    • 9815
    So - the door on my 90 has been replaced with one from an earlier model. The window works - but the switch is backwards - but i cant get the damn lock to work.
    Q1 - Can I swap in later model window internals?
    Q2 - Is the window glass different?
    On to lock problems....
    I replaced the tumbler. It should work - in theory - but in order to get it to lock/unlock - it needs to travel far enough to apply pressure to whatever mechanism is inside. In order for that to happen - the lock has to spin beyond it's mechanical limits. I hope you guys follow...
    Q3 - How do I fix?
    Q4 - Anyone have ALL of the late model internals to sell me? I'd rather swap it all if i can.
  • AlarmedBread
    • Sep 2006
    • 1510
    Q1 - Can I swap in later model window internals? Yes
    Q2 - Is the window glass different? Yes, so is the regulator. Early cars have worm type, later cars have X type.
    Q3 - How do I fix? The micro switch is on a flimsy bracket usually you can just bend it back to where it will get hit by the tumbler.
    • psloan
      • 9815
      It doesnt seem like the micro switch works every time. I ordered a new central locking computer - hopefully that will do the trick. Also, What i was referring to is what the arm on the lock assembly physically moves - or does that not matter?
      EDIT - I also have the correct regulator and motor. I guess i need to see what other parts I need to do the swap.
      • Teaguer
        • Sep 2004
        • 6167
        You'll aslo need the late model glass for it to work right .
        Or you can remove the slide rails from the glass and reposition them , but thats a nightmare and they will eventually fail .
