Ok i finally (after a week of struggling with stripped bolts on the manifold) pulled the head last night. Ok backstory - i have a snapped rocker arm and a broken timing belt. I got the head off and found no damage to the piston (besides a bunch of carbon) and the valve with the broken rocker has no visible damage either no bending, breaks etc... So i'm confused - did my rocker break due to the belt snapping or did the belt snap because the arm went???? Either way i feel lucky cause i'm sure it could have been alot worse.
Confused, but Happy - I guess
Did you take the valves out of the head to examine them? Sometimes they are only slightly bent, and you can't see it unless you spin it them a valve grinder, or something similar. Sometimes it's so slight that you won't even notice it when rolling it on a flat surface.
Definitely pressure check the valves once it's all assembled and make sure none of them leak. My favorite way to pressure check is with a little bit of soapy water around the sealing surface of the valve. Either do it with the spring installed, or use a screwdriver or something similar to press down REALLY hard on the valve, then take an air nozzle and blow in the port as close to the valve stem as you can get. You don't want any bubbles.
This is a perfect opportunity to rebuild the head and replace valve stem seals. Might as well do it now and save yourself from having to do it later.sigpic
Originally posted by kylebes1 View PostSo did the rocker only break?
T-Belt broke due to age. Rocker broke because the engine kept spinnign for a second and that is the weak link.
this belongs in Technical
Originally posted by kellie View PostDid you take the valves out of the head to examine them? Sometimes they are only slightly bent, and you can't see it unless you spin it them a valve grinder, or something similar. Sometimes it's so slight that you won't even notice it when rolling it on a flat surface.
