when should i do the timing belt again?
    Its been 4 years since the timing belt was changed. Ive only put 25K on her in that time. I know the service interval says 4 years or 60K miles. So am i OK for a little while longer? Also, ive never had a car running on full synthetic oil before. Ive had my e36 for almost 10k miles and have never changed the oil. the P.O. did it right before i got it. Am i due?
    both these cars are gone :(
    you live in conneticut, so the air is humidish and it doesnt get super hot, so you probably are ok.
    but then again, it is only 40 bucks, and an hour off your time to do it, better safe than sorry......
      Usually anywhere from 30-50k is the limit, so you should be good up to 50k. I'm not sure how brittle they become over time, but I'm sure it wouldn't hurt.
      BTW, another E30 person. I'm down in Shelton/Stratford (where I work) and live in North Haven.
      Originally posted by BillBrasky
      E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
      1991 318i Alpine II - S50/5-lug swapped - track car
      1989 325i Cirrusblau - Daily
      1970 2500 - Malaga over Grey Cloth
      2012 F350 6.7PSD
        Does it really only take an hour to do?
          well ive done it twice, so i already have an idea of what i am doing.if you take off the radiator, it goes by much much quicker.
            thanks for the tip.
              Including setup and teardown, it will take you all of 3 hours for sure. If you do remove the radiator there is more room and it's less likely you'll damage it. However, you will have to deal with coolant and bleeding the cooling system again.
              "If I were filthy rich I'd still drive my E30."
                They tell you the time or mileage since it is the best way to judge the life of the service. Another words just since you have only gone about half the miles but the time is where it is recommended that it actually could be dry rotten or getting brittle in some fashion. I do not think that I would push it to much longer on replacing it just incase. You are better safe than sorry you know.
                And oil changes I would never recommend going 10k between changes period. Personally even if the dealer recommends otherwise I would never push past 5000 max but always try to change every 3500
