Euro bumper install questions
  • psloan
    • 9815
    What do I need to install euro bumpers? I bought a set but with no brackets/valences. I know where to get the valences but don't klnow if they are needed.
    Thanks in advance
  • SchnellerVert
    • Sep 2005
    • 3948
    Don't need the valance amd you just need the proper rear drains and rear brackets plus the two front brackets
    • E30 Reaktionär
      Site Manager
      • 14451
      Here is some links for the part numbers for the brackets that you need. Just call whoever you like to get your parts off of and order some or you can make your own.
      Front; http://www.realoem.com/bmw/showparts...33&hg=51&fg=15
      Rear; http://www.realoem.com/bmw/showparts...40&hg=51&fg=15
      1992 BMW 325iC
      1978 Chevrolet Monte Carlo
      • psloan
        • 9815
        Drains? Don't follow.
        Thanks for the link. so let me get this straight - All I need is some brackets? No cutting, ect?
        • rThor432
          • Feb 2007
          • 3907
          No cutting needed. According to RealOEM BMW sells front and rear sets of mounting components needed. Off the top of my head I remember the RealOEM price for front mounting hardware is $45 and some change, so the actual price now should be about that.
          • E30 Reaktionär
            Site Manager
            • 14451
            You'll have to drill 4 new holes for the back bumper. And for the front you'll have to modify the wire connector for the turn signal cause euro bumpers don't have parking lights only turnsignals. I cut the end part off of mine that had the parking light wire in it, then i shaped it to fit into the turn signal connector in the light on the bumper.
            1992 BMW 325iC
            • psloan
              • 9815
              Sounds like cake. Thanks guys. Looking forward to no diving boards.
              • E30 Reaktionär
                Site Manager
                • 14451
                You'll love the euro's. They clean the car up really nice. Are you going to use a US or euro valance?
                1992 BMW 325iC
                • psloan
                  • 9815
                  Well, I guess what I have on my car now. I have the IS airdam - will that still work?
                  • E30 Reaktionär
                    Site Manager
                    • 14451
                    There was a guy over on e30 tech that wanted to run the early is air dam with euro bumpers, but i don't know if he got it to work? Propobly have to use the metal valance with the 86-87 lip.
                    1992 BMW 325iC
                    • psloan
                      • 9815
                      hm. Really dont want to run a stock lip unless it's the late IS lip.
                      • E30 Reaktionär
                        Site Manager
                        • 14451
                        This is the one you'll need, cause of your oil cooler. Or don't you have an oil cooler?
                        1992 BMW 325iC
                        • SchnellerVert
                          • Sep 2005
                          • 3948
                          The drains/vents under the rear bumper are differant part numbers and support the bumper to a slight degree.
                          Slightly differant and more aggressive.
                          • jms16v
                            • Dec 2006
                            • 314
                            is it possible to run euro bumpers with an 87 is front valence?
                            • psloan
                              • 9815
                              They already said it's not easy but someone is trying it. I like to take the easy way out. If i cant get it on easily ill buy something else.
