You've seen the black mess hardended on pulled heads...how do you clean this crap off?
How do you clean valves when rebuilding a head?
Originally posted by 86espowa View Postumm, buy new ones?
or use a buffer wheel.
three angle valve job too!
Buffer wheel might do it as long as it doesn't take any metal with it.
The black mess is better known as CARBON.
If your "rebuilding" a head, you need to take the whole head apart. Then heat tank the steel parts, and carb clean the aluminum head. After that check head for any cracks, surface if needed, replace guides, and the seats if needed. Clean valves with a steel or brass brush, and give the head and valves a three angle cut.
Personally if you have never worked in a machine shop, and do not know how to clean valves, it is better left to a shop that knows what it is doing.
I would never spend money on new valves unless you have one or some of them burnt, or they have been ground before, and can not be cut again. Also you need to look at the shaft to make sure there is not to much wear there, or galling . A micrometer is always good to use there to make sure the shaft is still good.Last edited by SandyEggoE30Girl; 08-09-2007, 02:39 PM.
Originally posted by SandyEggoE30Girl View PostI would never spend money on new valves unless you have one or some of them burnt, or they have been ground before, and can not be cut again. Also you need to look at the shaft to make sure there is not to much wear there, or galling . A micrometer is always good to use there to make sure the shaft is still good.
What's your definition of a burnt valve?
Originally posted by CorvallisBMW View Postcarb cleaner+brass brush
Exhaust valve 60.55ea
from Pacific Motorsports
Originally posted by 86espowa View Postnew valves are just shy of 140 dollars.
Originally posted by StereoInstaller1 View PostWhere? For all of them, or just one cylinder? You might be thinking Chevy....
from Pacific Motorsports (The BMW Shop)
Intake valve 26.70ea
Exhaust valve 66.60ea
from Rasmussen BMW
Im thinking BMW, if I was thinking Chevy I would be on a Chevy site...
from Rasmussen BMW
"86espowa" said valves are under $140, I was asking HIM where he thinks you can get M20 valves for under $140/set...I know better.
BMA quoted me about $30 each for exhaust, I did not check on intake. Last I checked my math, $140 will not buy exhaust valves, much less a complete set.
