DASC on an E30?
  • e30Matt
    • 5077
    DASC on an E30?
    I've got a '93 M42 in my '91 318iS. Does D/A make a supercharger that will fit my engine, and if so, would it fit installed in my car? Just out of curiousity, not seriously considering it or anything.
  • Jordan
    • 12912
    no, no, no, and no.
    https://mtechniqueabs.com/
    • Ryan Stewart
      I Love Miatas
      • 8978
      no prefab kit. You dont have the knock sensors that he DASC is built for. Its custom for you.
      Im now E30less.
      • e30Matt
        • 5077
        Cool. I was browsing around and figured I'd ask.
        • Charlie
          kid tested, administrator approved
          • 6686
          Was it the m42 out of the e36? (different intake manifold).
          If so, then yes, the DASC will mount up to that M42, you do have the knock sensors you would need. Not sure on the space limitations with the e30 hood, but I imagine it could be made to fit.
          -Charlie
          Swing wild, brake later, don't apologize.
          '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
          FYYFF
          • fabianyee
            • 195
            I think the belts used on the pre-95 M42 are different from the belts used in the post-95 M42...
            Correct me if I'm wrong.
            If you're using ribbed belt to drive the alternator, fan clutch and the PS pump, then it should be the same type of belt used for the DASC. Only that the DASC-provided belt is longer.
            BMWClub Malaysia
            www.bmwclubmalaysia.com
            • m42technic
              • 1056
              All post '92 M42's have knock sensors, the DISA intake manifold, and a serpentine belt instead of V-Belts.
              James Peacock
              WWFSMD?
              • e30Matt
                • 5077
                It'd be kind of interesting to have a 200+hp SC M42, but I'm not even going to bother dumping money into this pit.
                • Rob
                  • 8166
                  BMW made one, its called an S14.
                  BEERTECH
                  • BavarianBimmer
                    • 951
                    and they're also made in 2.5litre form producing 238hp (euro spec)
                    1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                    1997 E36 328iT
                    1990 E30 325iT 24v SOLD
                    1989 E30 325i 2.7i M-Technic II SOLD
