Paging dirtbike gurus
  • mudflaps
    • 808
    Im having a problem with my bike.
    It sat for 6 months without starting. 1995 Kawasaki KX125, 2 stroke, you know the drill. Kicked it over a few times and it started without much hassle. Ran for about a minute, bogged out, then shut off. Pulled the air filter, it was ok. Pulled the plug, it was all sorts of gunked up. Cleaned it off, reinstalled, and bike started right up. Bike ran for about a minute again, and bogged out just like the first time. Whats my next step? Im leaning towards trying to rejet/rebuild the carb, but im not sure. 6 months ago, I rode it up and down the street a few times without issue.
  • E30 Reaktionär
    Site Manager
    • 14451
    My 76 yamaha 175 enduro does the same thing. It is a carb issue. it proboply need cleaned out and freshened up. Then needs tuned in.
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • jmarch
      • Oct 2004
      • 163
      You probably have clogged you carb jets (especially the pilot jet which lives in gas and has the smallest opening). Your float valve is probably also sticking. Buy a rebuild kit for your carb.
      1995 Porsche 993 6 speed
      2001 BMW M3 6 speed - DD
      2001 BMW 530iA Sport - Hers
      2005 KTM 450EXC 6 speed
      Gone:
      1988 BMW M3 2.5 EVOIII Clone
      1988 BMW 325is x2
      1985 BMW M635CSI 286hp
      2001 KTM 400MXC
      • SchnellerVert
        • Sep 2005
        • 3948
        No stabil in the fuel tank correct?
        • mudflaps
          • 808
          no stabil.
          im guessing carb rebuild, the carb was leaking out the bottom ALOT, im guessing the bowl was full and it was just overflow.
          • AndrewBird
            The Mad Scientist
            • 11898
            Stuck needle and seat. Engine is running WAY to rich, causing the plug to foul and for the engine to stall. Not to mention the gas overflow. Rebuild is necessary.
            • mudflaps
              • 808
              yeah, i pulled the plug after the second shutoff, and it was moist, smelling of gas. i assumed it was pretty rich.
              • gazellebeigem3
                • Jun 2005
                • 3712
                replace the starter
                • mudflaps
                  • 808
                  Originally posted by gazellebeigem3
                  replace the starter
                  fyl.
                  go procreate with fagzotti, kill your babies, then go kill yourself.
                  • mudflaps
                    • 808
                    OT:
                    for real though, gazelle, never go to beanies muffler in reynoldsburg, they fucked my shit up pretty hardcore.
                    • gazellebeigem3
                      • Jun 2005
                      • 3712
                      Originally posted by mudflaps
                      fyl.
                      im sorry i dont know how to fix your dirtbike sweetheart. I know you really like me, youre just angry its broken. If you get that thing running, come by and pick me up. Ill throw a pity fuck your way.
                      • gazellebeigem3
                        • Jun 2005
                        • 3712
                        OT:
                        dude you should have known better than to go to 'da burg'. How bad are we talking??
                        • ivo316
                          • Oct 2006
                          • 1222
                          Don't think you need to rebuild the carb, just a major dissasembly and cleanup will do the trick.
                          While you are at it try tinkering with the main jet size, it does miracles on the KX.
                          I don't know if the 1995 model had this, there is a sort of box between the carb and the cylinder that has metal baffles, in spanish they are called "laminas", those are vacuum operated, and they open and close to flatten your power curve, to give you more power on the low rpm range. Those tend to stick too, so you need to clean that also, usually they were located in between the cylinder and the intake tube.
                          If you remove the carb and look into the cylinder you should see them blocking the view of what's inside, if there is nothing there, it just applies to older bikes.
                          • mudflaps
                            • 808
                            danke schoen
                            • mudflaps
                              • 808
                              they fucked up my zender front valence (cracked in about 4 places), and the tailpipes look as centered as a chinese downsyndrome child's eyes.
                              i was surprised, since everyone and their mom refered me to this place. I told this inbred son of a bitch that it needed a new muffler, he thought he could pull some magic, and tweak the M50 stock exhaust and bend it to fit. It definately doesnt fit, as I told him originally that it wouldnt. last time I go there.
