Changing Aspect Ratio
  • AndrewBird
    The Mad Scientist
    • 11897
    Can you change the aspect ratio of a video and then save it as a new file? I have the BMW M3 CSL Top Gear video, ut it is formated in the wrong aspect ratio. I can open it in Divx and change it, but I want to burn it to a VCD so I can watch it on my TV and it shows up wrong. Is there some way I can change it in Adobe Premier or some other program? Thanks for any help, I'm new to this. :) ;)
    Andrew
  • 92 mtechnic cabrio
    • 4907
    Try using VirtualDub, search around and you will find the program.
    R.I.P 07/01/09 - 04/23/10 :(
    • AndrewBird
      The Mad Scientist
      • 11897
      Problem. The CSL Video is in .wmv format and will not open in VirtualDub. I could convert it if someone could give me the name of a good video converter. Or does anyone else know a another program?
      Andrew
      • kencopperwheat
        King of Kegstands
        • 14396
        Which aspect ratio is it in now? 16:9? And I'm assuming you want to change it to 4:3? You'll lose a ton of the picture if you do that.
        Originally posted by Gruelius
        • AndrewBird
          The Mad Scientist
          • 11897
          It should be in 16:9, but it's in 4:3 so the picture is stretched height wise. Hence why I want to fix it.
          Andrew
