87 325iS Parts List Advice NEEDED
    I am looking to do a mini-overhaul on my 87 325iS with just about 140ish miles on it and have come up with this list... does any one have advice as to what else I might consider doing at the same time? If possible with prices est.
    BTW This idea all came about bc I need a left front wheel bearing.
    List thus far:
    Bilstein Sport Shocks
    H&R Sport Spring Set
    Front STABILIZER LINK
    Rear STABILIZER LINK
    Urethane Swaybar Bushings - Front
    Urethane Swaybar Bushings - Rear
    Suspension Mount Kit RS
    Control Arms L&R
    Front Control Arm Bushings
    Control Arm BRACKET
    Wheel Hubs FRONT
    Rear Wheel Bearings
    Tie Rod Assembly
    Brake Package F&R rotors, pads, senors, ect.
    Front Caliper Rebuild Kit
    Rear Caliper Rebuild Kit
    Transmission Mounts
    Engine Mounts
    Air Conditioning update
    Rear Trailing Arm Bushing Kit
    Shifter Bushing Rebuild
    I am looking to do most everything at once. I would like the car to be solid and long lasting. I have priced everything and compared the Dealer, Turner Motor Sports, Advance Auto Parts, Pelican, Flying Brick, ect.
    I've found most of the stuff at Turner, I am also considering their Suspension Mount Kit.
    Thanks in advance for the advice!
    Joe
    Boser Hood DIY
    Techno Violet Refresh
    Outsounding: Helping Children Discover Strength In Their Own Voice!™
    for the soild ride performance, go with poly on all bushings. Looks like a very through project list.
    what is your end goal? Occasional autocross, country drives, or just a good riding.
      I am looking for occasional driver schools, but mainly just a good drive over all.
      Boser Hood DIY
        Joe, use Urethane on the control arm bushings (I recommend AKG) and possibly the trailing arms out back, otherwise the car is going to be too harsh for most roads.
        I dunno why you would choose to do that entire list all at the same time though.
        Knowing what each change feels like is important.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
          Luke
          Most of the stuff is needs or will need to be replaced soon anyways, so figured that while i'm under there, and everything is apart, i might as well do it.
          So I guess I will pose this question...
          I know for sure that the left hub needs done, both tie-rods, both control arms, brakes, and the steering rack. SO I thought that the other stuff should/could be addressed at the same time.
          What would anyone suggest to do on top of these things, if I did not already have my list?
          I am open to any and all advice, I am very much a novice when it comes to these things, and bow graciously to those of you on this board!
          Thanks again btw, if there is a way to return the help/advice to this board please let me know.
          Boser Hood DIY
            OK, here is my call on that.
            If you need 2 tie rods, you REALLY need a new rack, so why not go E36? Find a used one under 100K miles, mod it, and rock.
            If the left hub is bad, so is the right...just not as bad. How much slop we talking about here? If you still have the wheel on, you are not testing it properly. Pull the wheel off and actually check it!
            Do a set of AKG CABs just so your brakes feel better, if you have any pad left at all. If no pad, time for brakie-poos, let your rotors dictate wether or not you need pads, or rotors too. Get Brembo OE replacement and Pagid pads, maybe flush out all the fluid in the entire car too.
            The CABs make more of a difference in turning, braking, parking...just damn near everything about driving an E30. Do it. I can do them in under 20 minutes. I assure you it is the best $50 you will ever spend on your suspension.
            Luke
            Closing SOON!
