where do i buy a fan clutch removal tool??
  • vivalegreg
    • Apr 2006
    • 1313
    i called all the local parts stores and they all seem to "not have one" or they just gave up looking for it because i need it for a ...da da dada....BMW
    where can i find one of these useful little buggers so i can fix my overheating issuess
    e30s r kool
  • Rigmaster
    • 3464
    all you need is a 32mm open end wrench.
    Some folks have found the perfect type at bicycle stores for pretty cheap, I found one at Northern tool- had to grind the head down a bit 'cause it was too thick to fit in the space, but now it works great.
    You need something to hold the pulley still, you can usually just use a screwdriver wedged between 2 of the bolt heads, then whack the wrench that you have on the clutch fan nut- remember, it's reverse thread- so you'll want to turn it to the right as you face the front of the car to loosen it.
    Bret
    • backtrail69
      • Jul 2005
      • 4471
      Bought mine at a bike shop. It is a headset wrench.
      :: PNW Crew ::
      '87 325 4dr, '74 2002
      • TwoJ's
        • Oct 2005
        • 4908
        Me too. I also made a tool out of flat stock steel to hold the pulley. Makes it very easy.
        • speedhop
          • 1509
          x2 they have plenty and are rather cheap...maybe $10-15
          www.ryanwhopkins.com
          • vivalegreg
            • Apr 2006
            • 1313
            wow good looking guys, looks like im going shoppin tomorrow at the bike store
            e30s r kool
