Help, please!
    Help, please!
    I'm fairly new to E30's still and would much like some more professional advice on some things. Thanks, here they are:
    1) The ride in my '87 325es sucks, needs suspension upgrade. Feels like no shocks/struts, only steel bars under there. I feel EVERY bump, no question about it, bad for the car. Will getting new shocks/struts take car of this? If I spend my money on new shocks or struts and the ride still sucks, I mean, what else??? What kind of shocks do you guys recommend? thanks
    2)Oil pressure sending unit that screws in beneath the block as been leaking a little bit of oil. Are there any special procedures for changing this? Does the engine have to be empty of oil/if it is removed when engine is oiled will oil gush out like you're draining it from the plug itself?
    3)When my A/C is turned on while my car idles, it occasionally makes this god-awful, terrible screeching sound that emanates from beneath the car making every single surrounding person within a damn half-mile glare at my car with a startled & very puzzled face. What the hell? :(
    Gotta go for now...will definitely think of more things and edit-post them either with this or separately. Thanks a hell of a lot for the help and generous advice. Happy E30ing
    -J
    about the oil pressure sending unit just park the car for a few hours and let the oil drain to the pan before you take it out. dident spill any oil when i did mine.
      tour a/c belt is probably loose. tighten her up or go to the car store and buy belt no squeek juice.
        bump
          With the shocks, it all depends on what you want for a suspension set-up. If you want a stock ride hight, go with some bilstein touring shocks and keep the springs you have, if they are stock.
          For a lowered look and firmer, more responsive look at this thread to get an idea. http://www.r3vlimited.com/board/showthread.php?t=52154
          When you decide what direction you want to go with your suspension, let us know. There are a bunch of different ways you can go with this.
          Good luck.
          Originally posted by Kershaw
