oil light
  • threlevenguy
    • Dec 2006
    • 1057
    oil light
    So my oil was low so the light came on the check panel, and it needed to be changed anyway. So i changed the oil and it was full, but the light on the check panel is still on for low oil. is there a bad sensor or something?
  • E30SPDFRK
    • 5714
    Probably a sensor, my car does the same thing. A dealer told me that if your oil level is good, ignore the light.
    Byron
    Leichtbau
    • PiercedE30
      • Apr 2005
      • 4220
      if your willing, you may want to pull the oil level sensor and clean the snot out of it. I believe someone posted a write-up on it and said that there is no way for a sensor to go bad, unless it gets dirty, then all you have to do is clean it.
      My 2.9L Build!
      • threlevenguy
        • Dec 2006
        • 1057
        alright ill look for that thread
