What causes sttering wheel vibration?
  • h0lmes
    • Nov 2026
    My steering wheel has recently started vibrating about 40mph. What are the possible causes?
  • atomic
    • Jun 2007
    • 5691
    tires need balanced probably
    • dkmr
      • Jan 2006
      • 332
      Might need new ball joints like me!
      • mattdk318i
        • Jun 2006
        • 3953
        ive had a wheel weight sling off without my knowlege. I proceeded to check everything because i had just gotten the tires balanced. Took me a while to find a clean spot on the rim where it was missing, lol
        • czag13
          • Mar 2006
          • 300
          sorry to threadjack, but what causes it to shake when the brake is pressed? My rotors are less than a year old, so I don't think it's that, anything else it could be?
          :(^SOLD^:(
          • atomic
            • Jun 2007
            • 5691
            rotors probably need to be turned and trued up
            • DuMa
              • 1101
              for me its the guibo
              • h0lmes
                Well I recently had a tire rotation at les schwabb, i wonder if that has anythign to do with it.
                • Joe318is
                  • Sep 2005
                  • 6451
                  tire balance and tire rotation are two different things. Does it go away after 40mph? If so, then its a balance issue.
                  Originally posted by vlad
                  • M42Technik
                    • 9781
                    Could be alotta things. Resurface your rotors, balance your tires, and basically replace all of your front suspension pieces one by one until you find the culprit!
                    Control arms, control arm bushings...list goes on...
                    Reminiscing...
                    • TopOfTheLine89
                      • Jun 2007
                      • 919
                      Cab
                      i hear CAB replacement clears that up.
                      97 tacoma 5 spd 4 cylinder
                      2001 330ci 5 speed
                      83 733i 5 speed, (FS)
                      • german g
                        • Feb 2006
                        • 1608
                        id say bushings
                        90is, longtube headers/straight pipe/mark d 18# 93 0ctane chip/18# injectors/vogtland springs/bilst. sports
                        :firehop:
                        • psloan
                          • 9815
                          I had a wheel bearing that caused it.
                          • monty
                            • Feb 2007
                            • 665
                            in my old car it was the tires. they were warped a little. seemed like it started shaking anywhere from 55-65mph. bought new tires, problem solved.
                            • Joe318is
                              • Sep 2005
                              • 6451
                              ball joints, tie rods, tire balance, flat spots, warped rotors, stuck calipers.... these can all cause said problems. NEED MORE INFO!
