Anal about maintenance/mods records??? How us...
  • george graves
    • 19997
    I've been slacking on keeping track of my crap. Post up some pics or just a description of what you do, and how you do it.
    Lets see some thick binders full of receipts, or some stories that inspire others to keep track of their shit....
    Should be interesting...
    Originally posted by Matt-B
  • JamesE30
    • Feb 2007
    • 2092
    shit i can relate to this.
    Ever since i got my car a few months ago ive been meaning to keep a full photo diary of its progress.
    I am yet to actually sit down and sort through everything into a dated display folder.
    Hence a have a butt load of invoices, receipts and photos just building up...
    Man i really need to sort through some stuff.
    ...Not to mention my bedroom is starting to look like a Pick-a-Part.
    I've got sterio equipment, rims/tires, seats, interior parts, lights and more shit just sitting over one side being disorganized.
    R.H.D
    M-technic I club
    • redbull 325is
      • 7471
      i made a folder with all my records, but at the end, no body cared :-(
      Build Threads:
      • dude8383
        • Jan 2005
        • 10387
        I just have a folder with every invoice sorted by date...its getting pretty thick =)
        • Joe318is
          • Sep 2005
          • 6451
          Ive got a thick folder and a flash drive full of images of the basic rebuild of my car. So when it gets hit i can give the insurance company the flash drive and they can tell me that its still only worth 1500.
          Originally posted by vlad
          • 2002maniac
            • 4260
            Screw that. I dont even want to know how much I've wasted on my car. Not like it would make it worth any more :shrug
            • Charlie
              kid tested, administrator approved
              • 6686
              Here's a complete list of my records & reciepts:
              Hmm, shit, yea, might want to do that sometime.
              -Charlie
              Swing wild, brake later, don't apologize.
              '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
              FYYFF
              • Jean
                • 18228
                Not exact as I stopped updating it for a couple of months... but close.
                <pre>
                Shift boot $15.00
                Shift knob $15.00
                Window handles $20.00
                Front emblem $12.00
                Front Ashtray $33.00
                Hood Shock $15.00
                Fuel, Oil, Air filters $45.00
                labor for hoses and belts $180.00
                windshield and labor $160.00
                Belts $30.00
                Coolant Hoses $60.00
                Belts and Hoses labor $180.00
                Cap, Distributor $30.00
                Rotor, Wires, Plugs $150.00
                Front Disc rotors, Pads $70.00
                Brake Lines $30.00
                Bilstein Sport inserts $408.00
                R Shock Mounts $16.00
                Control Arms $144.00
                CA Bushings $30.00
                Subframe bushings $40.00
                GC 500/650 $322.00
                Windshield and labor $160.00
                New used dash $30.00
                Clutch Kit $138.00
                GC Camber Plates $272.00
                SwayBar U Brackets $4.00
                Bosch o2 Sensor $39.00
                Sway Bar End links $44.00
                Tail Light Gaskets $20.00
                Sold the wheels/tires $(900.00)
                cd player delete faceplate $13.00
                ac fan brackets $8.00
                driver side air duct $17.00
                steering wheel horn contact $8.00
                ac fan bushings and brackets $45.00
                fuel tank hose $22.00
                valve cover vent hose $8.00
                valve cover gasket $9.00
                speed sensor $31.00
                diff cover gasket $8.00
                speed sensor gasket $2.00
                Thermostat behr $26.00
                Radiator nissens $149.00
                Water Pump behr $48.00
                accelerator cable $18.00
                tie rod ends $96.00
                tie rod boots and clamps $6.00
                ie urethane tranny mounts $70.00
                cab m3 bushings $80.00
                m-tech1 steering wheel used $45.00
                top radiator hose 11531278909 $10.00
                water pump hose 11531266472 $2.50
                alt adjusting bar 12311312137 $20.25
                2x alt bracket bush 11721261404 $6.00
                alt adj bar idler 12317677914 $3.95
                rad cap 17114379047 $8.00
                rad drain plug 17111719384 $3.00
                intake rubber boot 13541278947 $18.00
                used fuel level sending unit $20.00
                used euro grills $50.00
                used front plastic bumper $45.00
                used hella ellipsoids $45.00
                used alternator from bavarian $35.00
                3/22/2007
                misc clutch parts(master/slave & shifter parts) $160.00
                used good flywheel $95.00
                labor to install clutch $400.00
                labor for alignment $100.00
                falken azenis rt615 tires mounted $370.00
                Apr-07
                used rear plastic bumper $80.00
                2 front rotors 34111160749 $70.00
                2 rear rotors 34211119581 $57.00
                4 rear soft brake lines $48.00
                2 fog light delete plates $19.00
                used 3.73 lsd with redline $250.00
                May - August
                325 mc $130.00
                new rear side trim $60.00
                new oem floor mats $80.00
                Rear plate filler, front I lip, brake ducts $120.00
                Cluster rings $30.00
                Ansa sport cat back $150.00
                Momo steering wheel $140.00
                Momo hub $60.00
                Corbeau seats and brackets $750.00
                Pioneer cd/mp3 hu $140.00
                Polk db speakers $100.00
                Polk db sub $70.00
                spare 10 engine $200.00
                m10 head rebuild $320.00
                IE engine mounts $100.00
                Sparco? front bar $80
                September
                Guibo, CSB, Driveshaft bushing, nuts $100.00
                OEM transmission mounts $20.00
                $7,086.70
                </pre>
                • AlarmedBread
                  • Sep 2006
                  • 1510
                  I write down regular maintenance items in a notebook, but only to keep track of when last fluids, belts etc etc. were put on. I doubt it would make any difference if/when I go to sell the car how detailed my records are.
                  • delatlanta1281
                    Dart Master
                    • Mar 2006
                    • 10317
                    I have a drawer in my toolbox. It is 11 inches wide by 3.5 deep. Full of paperwork. Any paperwork less than six months old is on a magnetic clip on the side of my toolbox
                    Yours truly,
                    Rich
                    you kids get off my lawn.....
                    • Jordan
                      • 12916
                      I keep a spiral ring binder with all my paper invoices etc. It is really just a backup though.
                      I use computer software to do the real book keeping. CARCare to be exact. It tracks and logs everything you could want, and outputs it in forms that really show the bottom line.
                      Check this link for a output on maintenance items on my 99 M3 before I sold it:
                      https://mtechniqueabs.com/
