Hole in the Floor....
  • aworthybrother
    • May 2007
    • 899
    My car has a hole in the floor on the space between the driver seat and the front driver side window, close to the driver's seat belt area. looks like some screw is missing. the hole doesnt look like it was drilled or a damaged in the body. anybody has an idea what this is or what is the part number for the bolt needed for this hole? cant find it in realoem.com...thanks!
  • speedhop
    • 1509
    i feel like i'm in a box when i look at these pics...the best guess i have is the seat belt mount
    www.ryanwhopkins.com
    • aworthybrother
      • May 2007
      • 899
      The seatbelt is mounted on the seat
      • Mike325
        • Mar 2006
        • 3685
        There is a bar that the bottom of the seat belt attatches to. That is where the bar goes. That is the only thing that goes where you have a hole.
        Originally posted by Kershaw
        • SA E30
          • 1248
          If it's a 2dr it mounts to the floor on that bar, a 4dr mounts to the seat...
          That hoel looks like it's for the floor mount bar for the seat belt... the floor pans are the same on a 2dr and 4dr.
          on my 4dr there were these plastic type threaded screws in it.
          • mitch500
            • Jan 2006
            • 1092
            i like the shoes
            1988 e30 alpine white vert 5speed
            1987 e30 325 eta
            1983 e28 533
            2001 x5 4.4l
            1997 e36 M3 Alpine white 5speed
            1991 Jeep XJ I6 4.0
            • equate975
              • Jun 2004
              • 3382
              Maybe someone drilled it for a harness?
              Looks like he has a 4dr so there shouldn't be a hole there.
              Rollin' with a Geistkuchen
              • aworthybrother
                • May 2007
                • 899
                I have a 4-door. the bar where the seat belt is attached is bolted on the seat. this doesnt look like it was drilled. can anybody post a pic where the bar is bolted on the floor?
                • Mike325
                  • Mar 2006
                  • 3685
                  It is bolted right to the floor where your hole is. I guess the 4 doors have it mounted differently than the 2 door cars. I have a 2 door so I do not know how yours should be but it was stated and you stated that the 4 door location is slightly different. Does the hole have threds? I bet it was a normal part of manufacture to make the hole and they did not happen to need them on the 4 doors so they just plugged it off. This was mentioned eairlier in this thread. I know you have nothing to worry about because this is not a rust hole:o;).
                  • SA E30
                    • 1248
                    The 4 dr it is mounted to the side of the seat I know I just recently took seats out of a 4dr...
                    That hole is there for the seat bar on a 2dr, as the floor pans on a 2dr and 4dr r the same... there should be a screw type plug in that hole.
                    ... OR DO I NEED 2 REPEAT MYSELF AGAIN ? :) :P
                    • mtechnik
                      • 6156
                      It seems the prob has been firgured out
                      Originally posted by mitch500
                      i like the shoes
                      Yeah..Florsheim's? :D
                      • Van Westervelt
                        • 9365
                        x2. or is it 3 now :) Yeah, its normal, put there by the factory. Just usually has a plug in it. It is for 2 door seatbelts.
