temp rust repair
  • new2bmw
    • Oct 2006
    • 387
    temp rust repair
    just need to slow it down over the winter. i can grind to bare metal, then what can i put on cheaply to stop it till i can grind off my temp repair and work on it next summer? the car is being stored outside this winter. I was just going to prime over the metal but i heard primer is porous and will let moisture through, any suggestions?
  • Rigmaster
    • 3464
    Use some rustoleum primer + then cover with rustoleum paint. If you get it down to bare metal, then you shouldn't need to do anything else to it for a long time.......
    • TrackAddict
      • 111
      POR-15 will stop the rust. Good stuff!
      • Rigmaster
        • 3464
        Yes, it will- but it's almost IMPOSSIBLE to get it off once it's on there, plus it's pretty expensive compared to paint.
        Bret
        • Schneider325
          • May 2004
          • 3818
          Picklex 20 followed by zero rust is good.
          • new2bmw
            • Oct 2006
            • 387
            Pixle?
            not sure what that is? could i just spray some primer and a qick coat of any auto paint to seal itjust until spring? or if i just let it sit this winter how much worse will the rust get? i can tarp it. It will get a repaint in the end either way.
            • Schneider325
              • May 2004
              • 3818
              Network Solutions - Original domain name registration and reservation services with variety of internet-related business offerings. Quick, dependable and reliable.
