Could anyone point me in the right or preferably easiest direction for which vaccum line to suck "Seafoam" into? Thanks a ton...
Vaccum lines and "Seafoam"
Need a part? PM me.
Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Tags: None -
If you look at the top of your intake manifold on the exhaust side there is a vac line that goes from the manifold to your fuel pressure regulator. Pull the hose off of the FUEL PRESSURE REG. and suck it in a bit at a time. I did it a third of a can per time (three times). I jogged the throttle with my right hand while sucking the seafoam in so the car would not stall out. After a third was sucked in I turned off the motor and let the seafoam soak in for about 10 minutes. Then I started it and smoked out my street.Yours truly,
Rich
Originally posted by Rigmasteryou kids get off my lawn..... -
Yep. I did a burnout while my exhaust was smoking. It was very smokey to say the least:o:D.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
Which hose do I pull off the FPR; the braided hose going to the Intake manifold or on the other side (rubber hose)?
*EDIT*
Disregard. I re-read your post and got a clue...Last edited by ck_taft325is; 10-01-2007, 11:10 AM.Need a part? PM me.
Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Comment
Here's another quick Q: Did anyone else's "Check Engine" light pop on after a dose of "Seafoam" ?Need a part? PM me.
i seafoamed by street bike and got a bit over zealous with it because it liquified all the carbon which then stuck to the inside of the headers and exhaust, which continued to burn for 2 days straight when i drove the thing, smoking at every light.
runs like a top afterwards though!Comment
Update: My CEL (Check Engine Light) went off halfway to the gas station. I imagine it was just being a prat because I had the vaccum line disconnected to run the "Seafoam" through it. Thanks for the input guys.
The car itself runs like a champ now. The throttle response is increadibly nice and after the valve adjustment and two doses of "Seafoam" I can't even hear the damn thing while reving and it gets to 5500rpm (the most I feel comfortable reving to with 232k on the odo.) so much smoother and a tad faster in my opinion. Again many thanks to those that pointed me in the right direction on the vaccum line...Need a part? PM me.
Heh, I hate to admit it also, but I've gone out and bought about 15 cans of it for my own car as well as my fiance's '95 525i. Both cars run like champs and it cured alot of problems I wasn't expecting it too...Need a part? PM me.
Where can you get it? I've looked around at various auto parts stores and haven't seen it anywhere.Comment
I found my newly aquired stash of "Seafoam" at Schmucks.. but I did check Autozone and they also carry it as well. Hope that helps...Need a part? PM me.
