Back cut your valves! always!
  • ptownTSI
    • Jun 2005
    • 1265
    Very insightful article on carcraft.com for this month. they saw gains of up to 20% in flow from back cutting the valves. definitely a good read.
  • z50_Jumper
    • Apr 2007
    • 1520
    sweet, now all i need is everything to do the job. :)
    • ptownTSI
      • Jun 2005
      • 1265
      much cheaper to have a shop do it. you're in socal so you could go to their shop.
      • Jordan
        • 12911
        Indeed. My built M20 had 5 intake angles, and 6 exhaust angles. No doubt aided it in making the power it did.
        https://mtechniqueabs.com/
        • AlarmedBread
          • Sep 2006
          • 1510
          Would anyone be so kind as to suggest some good angles for valves on an m20?
          I'll be doing some head work soon and will definitely have some work done on the valves.
          Any other machine work that should 'always' be done when rebuilding an m20?
          • ptownTSI
            • Jun 2005
            • 1265
            That is on the cylinder head itself, its a multiple angle valve job, having the actual valve backcut is different and usually only involves one angle, say 30 or 32 degree's which is what is done on the domestic v8's.
            • Jordan
              • 12911
              Yeah, you are right. I didn't alter the valves at all.
              • golde30
                • 11464
                i had a 3-angle done on my s50 head while getting the valve-job done, i didnt request is, isnt it pretty standard?
                IG: @Baye30
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  I assumed this was common knowledge...
                  • Jean
                    • 18228
                    Same here.
                    • LINUS
                      • 2422
                      Yes - I've had 6 heads freshened up in life, and it seems like 3 - angle is a standard. I know one place that will do 5 - angle, but I've never bothered. Mostly because aside from 2 motor builds I've been doing them on the cheap.
                      Interesting article though - I'd never heard of cutting valves either.
                      It's not how you handle the good times, but the faith you keep in the bad that defines you.
                      • ptownTSI
                        • Jun 2005
                        • 1265
                        valve jobs grind the valve seat which is in the head, this process involves cutting the edge of the valve to draw more air in at low intake & exhaust lifts to improve flow.
