Ok, my brother bought a 525 with a m20b25 in it, the car will start right up and idle fine but whenever you hit the accelerator pedal it will get to about 2k rpms and them surge back and forth terribly, it will eventually rev up to 6k but it is very far from drivable. The exhaust smokes and smells of gas. We have new plugs (which are soaked in gas), cap, plugs, wires, all look good. Took off valve cover, no broken rockers or anything. We replaced the injectors, and fpr, still runs the same, hell it runs the same if you pull a plug wire off.......engine light says injector 1 or group one but injectors are new, also says fuel pump relay control, but we replaced and tested all the relays. We checked coolant temp sensor and it was reading the right amount of ohms, AFM getting right amount of volts.........I think that the AFM might be flat broke, or cat clogged up and exhaust pressure can't get out..........car has 240 K...........Please help your ideas are greatly appreciated.
Thanks,
Chris Estes
Thanks,
Chris Estes
