ENGINE OIL pressure warning light
  • franco90
    • 3185
    I have a Question I did a OIL change last week . Here is the problem the engine Oil pressure warning light keeps coming on and off before and after the oil change should I be worried?.Tonight after driving back home the light came on again this time the light stay on. should I be worried. this light has never came on before.:crazy:
    I've always been proud of being a Marine.
    I won't hesitate to defend the Corps
    "Supersquad"
    ‎"Prostitutes are a sub-category of Amusement Parks"-
  • Jordan
    • 12916
    Well either your oil pressure is too low to leave the engine running.. or its faulty.
    You can either guess its faulty and ignore a potentially fatal warning light, or you can replace it and see if the light stays off.
    https://mtechniqueabs.com/
    • franco90
      • 3185
      what does the part looks like so if I understand this correct I am looking for oil presure sensor Correct?..
      "Supersquad"
      • Bimmerista
        • Nov 2005
        • 5425
        Thats right...the oil pressure sensor can be found close to the oil filter. If I remember correctly, its the closest part to the oil filter with a wire. Best way to get to it is to raise the front of the car.
        Looks something similar to this
        • franco90
          • 3185
          do you think I hit the wire by accident when I replace the oil filter.
          "Supersquad"
          • Bimmerista
            • Nov 2005
            • 5425
            If the wire is brittle, yes it can break off.
            Clean the area around it with some brake cleaner. Then see if the problem persists.
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              When I changed the head on my e28, I left it off by mistake. It came on sporadicly (spelling?) until I realized what I did.
              Yours truly,
              Rich
              you kids get off my lawn.....
              • backtrail69
                • Jul 2005
                • 4471
                ixs are all different. Who knows.
                :: PNW Crew ::
                '87 325 4dr, '74 2002
                • bolognablake
                  • Jun 2007
                  • 258
                  Yeah, it could be in the trunk somewhere.
                  • Bimmerista
                    • Nov 2005
                    • 5425
                    Next to the blinker fluid resevoir
                    • Court M3
                      • Jan 2004
                      • 6713
                      dude perfect excuse to go to the junyard tomorrow and get one. We need to get together on Saturday. Going to Ben's place
                      Continuous For Sale Thread
                      323i s50
                      • Bimmerista
                        • Nov 2005
                        • 5425
                        The part isn't very expensive...just buy new & call it a day
                        • Jordan
                          • 12916
                          Yeah.. its like $6 new.
                          • franco90
                            • 3185
                            well took the car to the lift no luck I could not find the Oil pressure sensor?.
                            any member have a picture of its location
                            "Supersquad"
                            • Bimmerista
                              • Nov 2005
                              • 5425
                              You didn't happen to take a pic of the under side of your car on the lift? I can show you that way...
