Leaking Valve Cover
  • red
    • 447
    Leaking Valve Cover
    I've noticed the smell of oil, and seen some oil around one of the valve cover bolts
    This means the gasket needs to be replaced right and I might as well adjust the valves too. I can do it in class we don't start till Jan 7th.
    Is that too long to wait or does this need to be fixed now?
    I want to do it myself for the experience, but I don't want to ruin my car because it is my daily. I've got the Bentley and some tools + wire hanger, if I follow directions accordingly, I should be ok right?
  • M5wanaB
    • Aug 2007
    • 405
    pretty damn easy to do. I would recommend reading the write up on it at www.pelicanparts.com there is a great article on valve adjustment on there specific to our cars. As far as the valve cover goes. Try and snug up the bolts a little bit, just make sure they are all torqued to spec and keep an eye on your oil level.
    1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
    • red
      • 447
      Yeah the light's come on about 3 times so I've topped it off. It's on again so I'll tighten them and then fill er up some more.
      • TwoJ's
        • Oct 2005
        • 4908
        If it were me, I would not wait that long to fix the problem. It's easy, and you're leaking oil all over your engine bay and wherever you park. That would bug the shit out of me. At the very least, I'd replace the gasket and then do the valve adjustment in class.
        And like someone already said, make sure the bolts are torqued correctly when you change it. And make sure you've got some good feeler gauges for the valve adjustment.
        Oh, and this forum exists for a reason:
        • TwoJ's
          • Oct 2005
          • 4908
          Oh, and if it's leaking that much, make sure the valve cover is straight. It's aluminum and could be slightly warped, though I doubt it.
          • red
            • 447
            Thanks for the info. I posted in this section because I saw the engine oil pressure thread and thought this was the appropriate section, my bad.
            I'll probably do it next week on payday in that case and anything else that needs attention while I'm in there.
            • TwoJ's
              • Oct 2005
              • 4908
              No problem. I wasn't trying to be a dick about it or anything either.
              • einstein57
                • Jun 2007
                • 10780
                And try and get the valve cover gasket with the grey line. Too many bad experiennces with red ones.
                www.gecoils.com
                • red
                  • 447
                  Thanks for the tip.
                  Oh I knew, I browse the OT quite often and I am pretty sure I can tell when someone is being a dick on here :p
                  • Court M3
                    • Jan 2004
                    • 6713
                    damn wish I would have known this before I changed mine a couple of weeks ago! How can make sure the supplier sends the correct one?
                    Continuous For Sale Thread
                    323i s50
                    • red
                      • 447
                      Do I need to order 4 grommets as well as the gasket? I'm trying to find the grommets on pelican but it seems they have them only for the 318.. is that something only the 318 needs? Or is it that pelican parts doesnt carry it.
