refurbishing your shadowline trim
  • der affe
    Technical
    • Dec 2005
    • 8452
    i did a search and all i found was how to shadowline your chrome trim.
    i just picked up shadowline trim from a 318is part out, and was wondering if there was anything i should do to treat it before i put it on the car (less messy off of the car) to keep it minty?
    thanks,
    greg aka JOHNNY BRAVO
  • Teaguer
    • Sep 2004
    • 6167
    Uuh , Scotch-brite and SEM trim black maybe ?
    • der affe
      Technical
      • Dec 2005
      • 8452
      isn't it originally anodized black on the aluminum?
      • Teaguer
        • Sep 2004
        • 6167
        Yes I believe so .
        Just thought it would make a good base to just respray over , gotta hold up better than the non-shadowline .
        • der affe
          Technical
          • Dec 2005
          • 8452
          true! i shall *steal* borrow some from work tomorrow!
          weekend fun!
          • Jordan
            • 12916
            Shadowline is painted black, no anodization.
            Simply scuff it with scotchbrite and shoot it with SEM Trim Black.
            https://mtechniqueabs.com/
            • fwappy
              • Feb 2007
              • 362
              Regarding this.. I'm in the process of putting a few pieces back on after being painted, and I'm wondering how to get the back window trim back on (coupe). Do I need to pop the back window out from the inside (rubber), insert the trim into the rubber, then install it all at once? It doesn't seem to want to go in while the glass is in.
              "If I were filthy rich I'd still drive my E30."
              • Teaguer
                • Sep 2004
                • 6167
                You need to open up/widen the grove/channel while you work the trim into it .
                Helps if you've done it before or have the right tool .
                Tool is easy to make also .
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  good! i was worried about it flaking like when you repaint porsche alloy lugnuts.
