Im refurbishing a 1987 325i and dont know if Im going to sell it or not. The paint needs to be redone eventually but everything under the hood was/is touched. The car has 200+k on it but AFAIK doesnt burn oil. Ive not done the piston rings or valves but have done the following
Regasketted EVERYTHING (Head, oil pan, etc)
Carbon free pistons.
Getrag 240 tranny with poly bushings (shorter first and second gear)
3.73 LSD
Will have a new front window (old one is really bad)
AC delete (didnt work)
ALL new belts
New plugs, dist cap/rotor but wires are the same
Fresh(ish) master/slave cyl
Will have new motor mounts
New thermostat but same old water pump
Mostly new hoses
Does painted driveline count as a mod?
How much do you think the car is worth if I sold it when im done?
3.73 LSD
ALL new belts
Mostly new hoses
