why is my coolant boiling out
  • chrisesteschiro
    • 361
    Hello friends, am in gatlinburg, tn 5 hours from home and I woke up this morning headed out of the hotel, noticed that the car was up to temp and had no heat, then the car wanted to overheat, I pulled over and pulled the thermostat out and ran it without it. Now it runs fine when I bleed the cooling system, and isn't overheating. But everytime I turn off the car the coolant is boiling out the overflow to the point that I have to re-bleed the system. Help!
  • e304me
    • Feb 2006
    • 1374
    You might have a bad headgasket
    • bimmer8604
      • 3017
      head gasket.
      1988 M3, 97 840, 99 XJ
      DILLIGAF
      • boom-monkey
        • 1104
        May also be as easy as a new radiator cap.
        • Teaguer
          • Sep 2004
          • 6167
          Its getting engine compression in the cooling system .
          • PiercedE30
            • Apr 2005
            • 4220
            It got hot.
            My 2.9L Build!
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              Wait you have no tstat in it?
              How bout buying a tstat for 12 bucks and running the car with all the right parts. Bleed the system then see whats going on.
              Yours truly,
              Rich
              you kids get off my lawn.....
              • PeaveyBassist
                • Sep 2004
                • 3511
                headgasket/cracked head
                RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                Welcome e30 (brilliantrot '90 325is) 12/23/06
                DaveCN = Old Man
                My signature picture was taken by ME! Not by anyone else!
                If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                • StereoInstaller1
                  GAS
                  • 22679
                  might?
                  Test strips tell the tale sad or happy. Hie thee to an auto parts store!
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • chrisesteschiro
                    • 361
                    I took the thermostat out on the side of the road when it ran hot, it turns out I looked at the coolant cap, and the 2 seals were broke along with one of the splines, towed it 6 hours home and ordered a new one.....I think that it wasn't getting enough pressure and thus boiling out.
                    • chrisesteschiro
                      • 361
                      It was 8 degrees outside the morning it overheated, I boiled the thermostat and it never opened so my best guess is that the thermostat stuck, then popped the seales in my coolant cap..........
                      • TwoJ's
                        • Oct 2005
                        • 4908
                        What do you mean it wasn't getting enough pressure? If it got hot, it's more likely that your head gasket failed, or your aluminum head is cracked.
                        • WillisE30
                          • Jan 2007
                          • 831
                          It'll get hot with a bad radiator cap, but I think his head is probably cracked too.
                          sigpicFormer professional wrench thrower.
                          Current:
                          1988 325is S52
                          Former:
                          2008 Sparkling Graphite M3 Sedan(victim of home ownership)
                          1988 M5
                          1996 328is
                          • bolognablake
                            • Jun 2007
                            • 258
                            Pressure changes the boiling point of water.
                            Whether that has anything to do with his problem remains to be seen.
                            • chrisesteschiro
                              • 361
                              Turned out the o rings on the expansion tank blew, replaced it and its still running good.......
