camber plates !!
  • AndrewBird
    The Mad Scientist
    • 11897
    #151
    Once again, Go-Ped (note the throttle cable and brake cable).
    And besides, I didn't use those pictures for my senior picture. I didn't even submit a senior picture. Hell, remember, I skipped out on my graduation to go to the e30 picnic in Seattle. ;)
    Just to add, it doesn't bother me that you guys post that picture of me. IMO, it's one of the best photos of me (I take horible pictures), so post away. Go-Pedding is my hobby and I'm not ashamed of it.
    • psloan
      • 9815
      #152
      I vote heeter posts a pic of himself.
      • rwh11385
        lance_entities
        • 18403
        #153
        If you want a picture for more homo-erotic masterbation, there are already plenty posted on the forum...
        • psloan
          • 9815
          #154
          I knew you wouldn't do it :)
          Besides - I think you're the only person who masturbate to a picture of you.
          • Ral
            • 1486
            #155
            psloan and lance_entitites argue like an old married couple. Still haven't figured out who wears the pants though, probably lance
            sigpic89 M3
            • rwh11385
              lance_entities
              • 18403
              #156
              nice english there...
              here you go honey
              I'm the only white male... SB '07
              • psloan
                • 9815
                #157
                You look like the human version of a vienna sausage.
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  #158
                  OK this is actually about camber plates!
                  if you use them (camber plates) in conjunction with coil overs, is that going to change your location of the lower spring perch/stop? i thought they actually moved the top of your strut up just a little bit. am i wrong?
                  if so do i need to take that into consideration so i can get max adjust-ability height wise in either direction...up or down.
                  i have extra strutt housings, and since i am low$$ right now, to save $$ i have been working on the projects i have piled up to go on the car, insted of going out. i was going to go to work tomarrow and cut off and weld the lower spring stops. should i wait until i get the camber plates to figure the height requirements?
                  • thectrlguy
                    • Apr 2007
                    • 1042
                    #159
                    It's pretty clear...
                    • psloan
                      • 9815
                      #160
                      Get off the dude's dong already
                      • bmw_e30
                        • 442
                        #161
                        I have a Go-Ped. They're pretty cool.
                        I take mine to the track though. That's why I bought it. 180 bucks used from some kid a few blocks up from me.
                        It's bone stock still.
                        • AndrewBird
                          The Mad Scientist
                          • 11897
                          #162
                          I'm more of a cruiser, but still modified mine quite a bit. I'm running an RC big bore kit with a 1mm stroker crank along with a rocket key and stalker exhaust. Plus I've got ADA brakes and a 3rd bearing support with stainless spindle. I got it used (actually, my dad got it for me when I was in the 7th grade) and have ridden it ever since. It's great transportation in the summer. 100+ MPH FTW
                          • Jand3rson
                            • 37587
                            #163
                            I'll assume you meant MPG, Andy. :D
                            • 92 mtechnic cabrio
                              • 4907
                              #164
                              No no, you really can hit 100mph on a goped.
                              My friend Paul is good friends with Jason Fischer, the man who used to own Coast Ped before it closed.
                              He's djsqiigles on gopednation
                              He was the first to go faster than 65mph on the original Goped Sport with special coast ped engine work. (I think the engine was called g23LH? I forget)
                              (Ignore the random piston sitting on top)
                              R.I.P 07/01/09 - 04/23/10 :(
                              • bmw_e30
                                • 442
                                #165
                                What I meant by taking it to the track was that I take it to racetracks (Cal Speedway, Laguna Seca, WSIR, etc.) with me to cruise around in and see other racecars when I track my M3.
                                I'm sure you meant 100 MPG and not 100 MPH...........
