FK High Tec Suspension Kit 60/40??
  • DanGillan
    • Mar 2004
    • 4061
    im doing my suspension and i think i've narrowed it down to the FK high tec suspension kit. it comes with shocks and springs, with a 60mm drop up front and a 40mm drop in the rear for $595. same suspension that andy (killercalypso) has on his car.
    now i just gotta order it, unless anyone has negatives about this suspension i need to know about??? opinions? thanks,
    Dan
  • M-technik-3
    • 18946
    The only negative is that they are soft. And they should be good for our harsh roads.
    • DanGillan
      • Mar 2004
      • 4061
      a little soft is probably good because of how bad mass roads are, as long as they're not too soft. so will you help me with the install once i order them greg? that would be friggen sweet cuz i dont know what im doing. thanks,
      Dan
      • T.Dot E30
        • Mar 2004
        • 536
        Fk shocks are stiffer than bilsteins.
        I've heard ppl say the springs sag, but i dont think that is tru, no one had any hard evidence except they say someone told someone bah bah
        • Brew
          • 3060
          Andy told me that his spring rates were 450f/600r....definitely not soft at all.
          '91 318is
          • M-technik-3
            • 18946
            The springs in my car were manufactered by FK for Koni and I'll say they are soft for one. That is why when I find the spring I want they are history. They are truely a $125 set of springs.
            I'm leaning to H&R as i don't like the Eibach's I have, or maybe Ireland's Stage III.
            • Mystikal
              Wheel Fitment Expert
              • 9602
              FK 60/40 kit = soft. Good if you want a stock ride quality...
              It slams the late-model car way too low in my opinion. Tucks all 4.
              • mikeedler
                • 6707
                FK is not a quality suspension! It will be ok for cruising, but the stock will perform better.
                I had FK in my wife old golf, and the shocks are pure crap. they are the thinest dinkyest junk I have ever seen. The shocks also blew a few weeks after I got them too. nothing but problems. And I am positive on the road(not on paper) that the bilstiens are 100% better and a whole lot stiffer if you go with the fat M tech style.
                • T.Dot E30
                  • Mar 2004
                  • 536
                  why are you bringing ur golf into this, jus bcus it was made my fk doesn't mean its gonna perform the same.
                  I have fks on my car, and im happy with them. I dont track my car, its my daily driver/ only car....they may be too soft if u wanna track ur car, but u should be getting a race setup if thats the case......then compain about how stiff it is and how hard the bumps are.
                  EDIT: one more thing, My Fk kit has lifetime warrenty. So if the shocks blow, they are gonna replace them.
                  • DanGillan
                    • Mar 2004
                    • 4061
                    mine is an everyday driver as well. how do you like your kit? i dont want it too stiff because there is nothing but bad roads around here and i will never track my car. did it improve cornering and handling? tell me more about your opinions. thanks,
                    Dan
                    • T.Dot E30
                      • Mar 2004
                      • 536
                      Definately improves handling, esp at high speeds. My fav is on slight curves on highways doing 140km. Recommended speed is usually 80.
                      The ride is not so bad I like it alot. I expected it to be way stiffer since the rep told me it was stiffer than H&R bilstiens combo. which i was gonna get.
                      The roads in toronto are pretty bad.....but i try to aviod it, the car does get noiser.......but my music is always pretty loud anyways.
                      I like my ride compared to other lower cars i've been in. I have yet to ride in another lowerd e30 thou. I will get a ride from Jay (Mystikal) he has GCs and koni's.........at first he was complaining about his being stiff
                      Check out the member rides sooon, ill be posting pics.
                      • rwh11385
                        lance_entities
                        • 18403
                        Jay = waffleswaffleswaffleswaffleswaffles :P
                        We got waffleswaffleswaffleswaffleswaffles spring rates yo. The only reason I complained what because my rear sat TOO low and i was riding on bump stops. The ride is very nice when the shocks actually do something.
                        Dan, you'd be better off buying Adam's used H&R sports + bilstein sports.
                        • Mystikal
                          • 9602
                          GC + Koni + Toronto = serious evasive moves.
                          My ride is stiff as fack, no matter what you people say. On glass roads anything will feel comfortable, try coming to our winter-ravaged pothole-smothered excuse for a roadway system and call me a waffleswaffleswaffleswaffleswaffles again.
                          If I had to do it again I'd probably still go with this setup, because I'm flat astounded by the handling capability, which will only be further experienced with my first auto-x coming up in 2 weeks. But I'd be lying if I said it felt anything like any OE suspension over the rough stuff.
                          • rwh11385
                            lance_entities
                            • 18403
                            stiff? stiff? 300/475......
                            If (When) I get a second ride, it'll get 450/600 springs. :twisted:
                            • M42Technik
                              • 9781
                              FK shocks suck. Springs are good, but could be stiffer, better....
                              Andy (KillerCalypso) has Koni shocks. Their springs are okay. I am going to go this route, but rather with Bilstein Sports because I'm not rich and can afford Koni shocks. And Fk springs are really a last resort for me, looking for Koni 60/40 springs (made in Germany only for E30's).
                              That is the bottom line. And try ebay.de you can find the whole kit that you found for $595 for E30's for around $300 (includes exchange rate). I think it was less even...
                              Reminiscing...
