Torx socket size on inspection cover?
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    I'm trying to finally replace my oil pan gasket, which I am pretty sure is guilty of turning the bottom of my car into an oil slick, but I don't have any torx SOCKETS. There's two(?) different sizes on the back of the inspection cover holding it to the transmission and I don't know either of them.
    Anybody know right away what size they are? I don't want to be still working on it when its dark :)
  • erik325i
    • Jan 2005
    • 3567
    Those little guys are E10.
    The large ones are E14
    The starter ones should be E12 I think
    Here's a little trick if you don't have that socket. I've had success using a normal hex socket when I had to get the small bolts out and didn't have that tool with me (junkyard scenario). I believe an 11mm fits pretty nicely. It's not a perfect fit, but those little bolts are not tight enough to cause any damage.
    -Erik
    • Justin B
      Sikky Nar Nar
      • Mar 2005
      • 4273
      Cool, thanks Erik. Ill go try that out and see what I come up with. Maybe I'll be making a trip to go buy some sockets though :D
      • wayfast
        • Mar 2005
        • 178
        fyi, harbor freight has a set of torx sockets for like $8
        • homegrone30
          • Jun 2007
          • 1449
          i think one size of torx comes off with and 11 but i know the smaller ones will come off with an 8
          • Justin B
            Sikky Nar Nar
            • Mar 2005
            • 4273
            I ended up using some SAE size to take them off, then an 8mm to put them back on. At least its done. What a PITA of a job that is.
            • WillisE30
              • Jan 2007
              • 831
              If you're going to be doing it on a regular basis buy the right sockets. Those fasteners are a nightmare to remove if they strip.
              sigpicFormer professional wrench thrower.
              Current:
              1988 325is S52
              Former:
              2008 Sparkling Graphite M3 Sedan(victim of home ownership)
              1988 M5
              1996 328is
