Cam Shafts
  • Letoyrider
    • Mar 2004
    • 121
    Cam Shafts
    Well i took my car to the shop today(close friend of my dads) to get a new Valve put in and well we figured out i need a new Head ( i got one from my old car) and a cam shaft and my dad heard you could increase power with different Cam's and he liked that idea...so i have no idea about cam shafts but learning slowly about the car though..so could ppl help me out here (this post is basically for my dad) if you know of a good cam please say so and a reason there good would be nice too...
    thanks a bunch
    Chad
  • Rob
    • 8166
    you wont gain much, if anything buy just throwing a cam in there. you need supporting modifications to the motor.
    BEERTECH
    • Letoyrider
      • Mar 2004
      • 121
      how about anything else you can stick in there..lol sorry im still a newbie to car engines
      • Jon '92 325ic
        • 172
        you could have the head ported.
        The intake and exhaust openings would be ported to match the openings on their respective intake/exhaust gaskets. But like Rob said, this would only be appreciatable with other modifications (e.g. an Extrude Hone intake manifold and shorty headers with a free-flow cat back exhaust)
        • Rob
          • 8166
          I'm also refering to bottom end modifications that increase compression to take advantage of the more aggressive cam
          BEERTECH
          • E30godz
            • 1524
            if anything see if you can get the head shaved, or block decked to increase the compresion a few points. More aggressive cams like the higher compression. and 8.8:1 on an NA engine, is not exactly extreme.
            • BavarianBimmer
              • 951
              what do you think of an engine rebuilding ????
              My opinion is modify your engine and use a matching cam,
              don't match your engine on your cam
              1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
              1997 E36 328iT
              1990 E30 325iT 24v SOLD
              1989 E30 325i 2.7i M-Technic II SOLD
              • Letoyrider
                • Mar 2004
                • 121
                thanks guys
                i was going to rebuild the Engine out of my 87 325i but then i found out i needed the head so i guess ill have to wait an see if i can get an other head cheap or if i should just go for a m50 engine....(ive been heading towards the m50 for quite some time now)
                well thanks for the sudjestion they say ill be back on the road by wednesday
                • Rob
                  • 8166
                  m50 is a better bet in the long run
                  BEERTECH
                  • rwh11385
                    lance_entities
                    • 18403
                    I'd swap in the more advanced engine long before rebuilding the M20.
                    Unless there was some vital reason to keep the M20, like class restrictions.
                    btw, cams can increase performance a lot on engines.....but it just doesn't help the M20 that much. Chad, your dad should look at other cars, and check out how cams increase power.
                    • Letoyrider
                      • Mar 2004
                      • 121
                      alright guys thanks
