does motronic (#173 or #153) perform any AFR corrections?
  • mspiegle
    • 1026
    I have a 173 box in my '87 325is and i am using an SMT6 piggyback unit. I was curious if the motronic box attempts to correct the A/F mixture at all to achieve a 14.7 AFR or whatever.
    I'm just worried that I would be fighting motronic if i'm trying to tell it to give more fuel and it doesn't want to.
    I think i heard somewhere that at WOT, the O2 sensor is ignored... is that true?
    Also, as an additional question, i just wired the SMT to control my ignition timing. I am able to advance or retard 12 degrees with a throttle/rpm map. What kind of numbers should I be working with? Is there some kind of general rule (eg, advance with higher rpms or something like that). I know with tuning the AFR, i'm trying to get the mixture to around 13:1, what am i aiming for when i do timing modifications?
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
  • rs4pro3
    • 5808
    This might help some http://autos.groups.yahoo.com/group/mod_m20/message/599
    85 325e 2.7 ITB'd stroker
    • mspiegle
      • 1026
      well crap, that's discouraging.
      I notice that when i'm running 6K rpms @ WOT, my SMT6 map is programmed to increase the AFM voltage by 20 points - this throws the voltage just over 5 and when i'm hitting those rpms, my check-engine light comes on for a second until i shift and am @ lower gears. I have not had a constant check-engine light though.
      With some work, i have been able to get my AFRs down to the mid/high 13s. I'm working towards low 13s right now. I'm gonna install my larger injectors and see what happens.
      maybe i need to get standalone engine management.
      Michael Spiegle
      '99 M3 / Track Car
