318i suspension on 318is
  • KevyWevy
    • 126
    hey guys, i was just wondering how interchangeable suspension parts (struts, springs) are between a 1984 318i and a 1991 318is. im looking at a parts car with some after market stuff that i would like to put on my 318is that i bought yesterday. just curious if the suspension differs since the engines are different.
    thanks guys!
    KEVIN
  • Erik j
    • Jan 2008
    • 939
    The 318i will have drum rear brakes while your 318is has discs. Thats the only thing I know of. Struts should fit, and so should springs. But I wouldnt swap anything else.
    Tri color fabric for sale here!
    http://www.r3vlimited.com/board/showthread.php?t=105922
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      Dont use anything from the front if its an 84-85 318i.
      • Jean
        • 18228
        84-85 318i will have smaller diameter front struts. rear trailing arms will have drum brakes. front struts will have thin solid rotors. no abs.
        I should do it the other way, not this way you are thinking.
        • gearheadE30
          • Jun 2007
          • 3734
          I think that all of the suspensions from the 325s are the same. Spring rates are obviously different, though.
          Project M42 Turbo
          • KevyWevy
            • 126
            so then the struts aren't interchangeable, but the springs may fit?
            im not sure if its really worth it then... hmmm
            • gearheadE30
              • Jun 2007
              • 3734
              no, it's not. You will end up doing a bunch of work to get inferior parts installed.
              Project M42 Turbo
              • Jean
                • 18228
                Was 325 mentioned anywhere by the OP ?
                • gearheadE30
                  • Jun 2007
                  • 3734
                  No, it wasn't, but I didn't know if he might also have access to a 325 parts car.
                  Project M42 Turbo
