Wet E30
  • eshghehBMW
    • 162
    Wet E30
    Hi guyz, new here from BFC.OT
    My driver side has been getting wet lately and I don't know what it can be.
    There's absolutely no rust and Today when I removed the carpet, I saw yellowish water (maybe just from the spungy stuff?). I can't tell If it's just moisture OR some kind of leakage from air conditioner hoses???
    There was alot of water, I would say.
    PS. keep in mind it's only on driver side.
    Thanks
  • george graves
    • 19997
    Heater core, heater pipes, or clogged sunroof drain.
    Originally posted by Matt-B
    • dlmrun2002
      • Apr 2007
      • 808
      Does it smell like anitfreeze? If not possible bottom corner of windshiled gasket where water sits and leaks under inside. You can lift up gasket and squirt some silicone between seal and gasket in bottom corners and that can stop water from leaking in .
      HTH
      DLM
      • eshghehBMW
        • 162
        HTH
        DLM
        Ok, it doesn't look or smell like antifreeze.
        AND on the side note, It hasn't been raining.
        • blownbrick245
          • Jan 2005
          • 499
          the carpet padding will tint the fluid a strange color, but that probably is your heater core as stated. atleast someone didnt break your window, prior to a 4 hour rain storm, while you were out to sea. i had 4 inches of water on the passenger side, and i didnt realize. started the car and fried my amp which was under the passenger seat...i hate fucking vandals /rant
          but good look with the repair
          -Max
          • bmw325csi
            • May 2007
            • 4045
            well my car did the same thing on the passenger side so i lifted the carpet and it was the drain hole. P.O prolly lifted the car from the drain hole and cracked the seal around it. I used some windshield epoxy to put it back on. no problems yet.
            harry/harout
            • eshghehBMW
              • 162
              -Max
              Damn it, it all started since I used my rear frosters??
              cuz I havn't ran the heater or the air conditioning AT ALL although they both work.
              • eshghehBMW
                • 162
                ya, sounds like I gotta take the whole carpet out tomorrow.
                So i'll keep busy. lol
                • WillisE30
                  • Jan 2007
                  • 831
                  I had a similar problem last year with my car. There are some rubber body plugs in the floor that can become damaged by inproper jacking or road debris which will lead to a wet floor.
                  sigpicFormer professional wrench thrower.
                  Current:
                  1988 325is S52
                  Former:
                  2008 Sparkling Graphite M3 Sedan(victim of home ownership)
                  1988 M5
                  1996 328is
                  • eshghehBMW
                    • 162
                    Can some1 confirm that:
                    The heater core can bust due to use of ONLY rear defrosters?
                    • eshghehBMW
                      • 162
                      Thanks everyone,
                      I did some further research on my own and I will look for every possibility tomorrow.
                      • jflip2002
                        • Sep 2006
                        • 4377
                        LMK if you need help with anything next weekend. I'll be back in the NO then.
                        Originally posted by blunt
                        • einstein57
                          • Jun 2007
                          • 10780
                          it will corrode and bust when not in use after 19 years of corrosion has taken its tole.
                          www.gecoils.com
                          • eshghehBMW
                            • 162
                            Can't think of anything right now...But I'll let you know...If you need a set of extra hands and no expertise, let ME know. lol
                            PS Do you know a good junkyard or two In NO town?? cuz I got a new list of junkyards, that I havn't been to yet.
                            • jflip2002
                              • Sep 2006
                              • 4377
                              No, Ive never been to any in Fresno. I can get you OEM E30 parts 10% above cost though.
