sos someone help fast
  • homegrone30
    • Jun 2007
    • 1449
    ok so im doing a 5 speed swap the tranny is from an 87 driveshaft from an 86 and the guibo wont match up so my question is will the bigger guibo fit on my driveshaft or do i need to find a different driveshaft? also would i just be able to pull the output flanges and swap them? i dont want to but i need to get my car running asap. ill be checking back alot since im kind of at a stand still. Oh yeah if it helps the doner car has the little harmonic balancer and the swapped car dosnt.
  • golde30
    • 11464
    the larger stuff is offa ETA, i think you can swap out the output flange on the tranny to make it work.
    IG: @Baye30
    • homegrone30
      • Jun 2007
      • 1449
      yeah that what im trying i need to get a socket and ground it down anyone know what size the nut on the output flange is
      • homegrone30
        • Jun 2007
        • 1449
        alright well update i swapped output flanges and now my center support bearing is too big is there two different sizes? well ill call the dealership and see if i can get something figured out.
